Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-04-2010, 11:01 PM   #1
HlhnEast
CF Senior Member
HlhnEast's Avatar
Default L98 Distributor Cap
I was looking at Taylor distributor caps on Summit.com in prep for a major tune on my stock '85 L98. I was gonna order it but noticed it was a screw type cap. Its dark and the car is covered so I was hoping somebody would help this lazy boy out and confirm the screw type cap is correct for my car. I could wait til tomorrow and look myself but.....well....
HlhnEast is offline   Reply With Quote
Old 09-04-2010, 11:05 PM   #2
rodj
CF Senior Member
rodj's Avatar
Correct
L98 has screws
rodj is offline   Reply With Quote
Old 09-04-2010, 11:30 PM   #3
John A. Marker
CF Senior Member
John A. Marker's Avatar
Screws not "L" swing bolts.
__________________
1995 LT1 6 speed - stock.
SOLD to son ** 1985 Coup -ZZ4 balanced, LPE 74211 , AFR 180 heads, SuperRam base, runners & plenum, cut out air box, K & N , power coupler, 52MM TB, March pulleys, AFPR, Accel injectors, Walbro FP, 1.6 RR, chip by TJWONG, 160 stat, cut back plugs, 8.5MM MSD wires, custom camber-brace,TRANSGO shift kit, 2400 stall converter, cross drilled rotors, SS brake lines, VBP camber rods, IAS Edelbrock shocks, exhaust, Magnflow cat, 3.07 gears, 13.2 @107.2 MPH in 1/4
John A. Marker is offline   Reply With Quote
Old 09-05-2010, 12:09 AM   #4
HlhnEast
CF Senior Member
HlhnEast's Avatar
Thanks guys, you da bomb!!! I'm gonna order it now.
Old 09-05-2010, 01:29 AM   #5
HlhnEast
CF Senior Member
HlhnEast's Avatar
Now this is odd. Please tell me this cap
http://www.summitracing.com/parts/TAY-948131/?rtype=10
Is the same as the cap in this kit:
http://www.summitracing.com/parts/TAY-918131/
Anybody see why this is odd?
Old 09-05-2010, 09:33 AM   #6
floridamale
CF Senior Member
floridamale's Avatar
They may have the photos & description switched you would think the cap & rotor would be the higher priced one
Call them and check
floridamale is offline   Reply With Quote
Old 09-05-2010, 09:53 AM   #7
Keystring
CF Senior Member
Keystring's Avatar
Different numbers.
Not sure why the kit would be cheaper.. But hey.. cheaper is better!
Keystring is offline   Reply With Quote
Old 09-05-2010, 10:51 AM   #8
Churchkey
CF Senior Member
Churchkey's Avatar
You can use a cap with the "swing" bolts, cut the "L" off each & remove the remaining hardware.
Churchkey is offline   Reply With Quote
Old 09-05-2010, 11:35 AM   #9
HlhnEast
CF Senior Member
HlhnEast's Avatar
Quote:
Call them and check
The kit number is the same on eBay. Summit sells most things there altho the cap isnt listed singly. I surely am not gonna point out a mistake in the favor of the Vette brothers. I just thought it strange the cap separate was more expensive than the kit alone. Especially $7 difference. All I hafta say is .
Old 09-05-2010, 02:16 PM   #10
HlhnEast
CF Senior Member
HlhnEast's Avatar
We will see in about 10 days on the kit. Kinda thought that was pretty long considering Summits usual speedy service. I also ordered a Summit wire separator kit that has the OEM style routing. All I hafta do now is grab some plugs and I am ready to do the tune.
Old 09-05-2010, 06:45 PM   #11
corvetteronw
CF Senior Member
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14
Support Corvetteforum!
corvetteronw's Avatar
I ordered a new distributor from Summit for my 91 L98 and they sent me one with a vacuum cannister on it. I specifically searched for one to fit my specific car and engine. They do make mistakes. My money was refunded within 1 week although I had to pay to ship it back.
I bought a rebuilt distributor from my local NAPA guys. My counter guy owns an LT1 Impala SS and knows his Chevys. I have never been burned by them. Their computer system works great and if they can't find what they are looking for they will research their vast array of catalogs. The only thing they could not find for me recently was a new fuel pressure regulator diaphragm.
corvetteronw is offline   Reply With Quote
Old 09-05-2010, 07:39 PM   #12
c4cruiser
CF Senior Member
c4cruiser's Avatar
The 948131 cap is described as "Clamp down" and the 918131 is described as "Screw down". The 918131 is the correct L98 Corvette cap.
I had originally ordered an MSD cap and rotor (MSD-8416) for my 87 as Summit showed it as the correct setup when you went thru their pat selection procedure. Even the MSD website showed it was the right cap. Turns out that Summit has the wrong cap listed; even the Accel cap is the wrong one.
I called Summit and they swapped the caps for me and even gave me a credit for the lower priced Taylor cap.
c4cruiser is offline   Reply With Quote
Reload this Page L98 Distributor Cap
Tags
85, 87, c4, cap, corrected, corvette, dist, distributor, ditributor, l98, location, order, remove, rotor, summit
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
