x-pipe just installed
Today I had my x-pipe welded in. My reason was to get rid of the "drone" sound that I get when I'm running highway speeds between 1600 and 2100. All I had was a stock system with Magnaflows out the back. I'll be the first to admit I was impressed with the lower tone and the ride on the highway was great, I could actually here my wife ( no jokes with that last statement) I truely thought that I was wasting my money but for $75 for the pipe and $50 for the install, it was well worth it. I plan on getting some sounds clips put on here soon.
Looks like you had the exact same exhaust that I now have on my LT4. Magnaflow mufflers out back and the resonator has been removed and replaced with straight through pipes. I think it's louder inside than it is outside. In the RPM range you gave in your post, my interior drone is head splitting. I guess I need an X to break up that resonance. (About the only thing I can afford right now)
Are you planning on going to Biff's on Friday? If so, I'll meet you down there and you can hear mine with the x pipe installed.
I agree with lower tone, but thats about as far as I'd go with mine. Def did what it was supposed to, but was hopin for an even more toned down interior. Still waiting to see somebody move from an x pipe to magnaflows x-resonator and give their review.
Location: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Replaced my 3 inch B&B cross flow resonator with one of their X-pipes. Should have done that on the original purchase/install. Drone is down and the tone is even more aggressive. At 61, I still haven't found a pipe that's too loud...
The deafer I get, the quieter it gets!
Any comments on this X-Pipe? I would guess you'll need some adapters since it's only 12" but it's stupid cheap and SS.
http://cgi.ebay.com/ebaymotors/2-5-S...#ht_6599wt_941
The power comes from opening up the exhaust. A slight add comes from the scavenge effect but ultimately the H-pipe is to counter the noise from opening up the exhaust.
The X-Pipe on the other hand is more effective in sound cancellation. By forcing the exhaust streams to collide, some sound frequencies are cancelled. (In a much larger range than the H-Pipe.) You would think the two exhaust paths colliding would cause more backpressure. In reality, the exhaust flow mass follows the path down the same side. (Bending around the inside of the X.)
The sound frequencies cross paths of the exhaust. Cancellation of like frequencies occur even though the mass of the exhaust flow hits and deflects into the same side pipe.
This is all assuming WOT condition or near full mass flow rate. At lower flow rate, the X-pipe does make the low frequency idle sound a little irratic. Something desireable in a Mustang or Corvette. But a Cadillac wouldn't care for it.
This is used as a band aid in tuning high performance vehicles to meet the legal pass-by requirements. Something that is difficult to do on a car like the Viper Roadster or Corvette.
The X-pipe idea was tried on the Viper roadster but ultimately they used the H-pipe design. If you've ever seen the OE system on a Viper Roadster, the exhaust exits the headers, enters an un-Godly hot converter that I have seen damage body panels and melt basalt packing back into a crystal solid. It runs down the side of the car into the main muffler and then to the rear axle. Then it turns to the opposite side and hits the H-pipe which is over the axle and exits out before the axle on the opposite side of the car. If it were not for the Pass-By requirements, this would be an easy design.
Designs like this and the birth of the X-pipe all stem from the need to meet the requirement. Again, the X-pipe just allows the exhaust to be opened up more while tuning out undesireable frequencies. It's ability to "add" power is a debate most drawn up by aftermarket marketing managers. Everyone loves a gadget.
