airconditioning problems
Ive been having some problems with the a/c lately on my 95. It still works and blows air but only through the bottom vents under the dash. none of the vents on the dash or above it blow any air at all. Does anyone know how to fix this or know whats wrong?
I think that the lower vents are default if no vent doors are moving around. I would suspect a cracked vacuum connection at the engine. Maybe an LT1/4 owner could help locate that connection. If it is not a vacuum problem, then the programmer could be suspect.
defrost is default under as many conditions possible. Reason for this is so hopefully it will defo the windshield so you can see. Sorry I do not have a diagram for you car here to help you.
