How to do the weatherstripping?
Old 08-04-2010, 05:23 AM
darkstallion_69
darkstallion_69's Avatar
Default How to do the weatherstripping?
Ordered a new weatherstripping kit. Wanted to know what I would need to remove the old one and what do I use to put the new one. Thanks
Old 08-04-2010, 06:56 AM
massiveB
massiveB's Avatar
watching this one, thinking about doing the same thing. mine are ripped/torn to the point i dont like taking the roof out. i thought i remembered reading it was a pita
Old 08-04-2010, 07:02 AM
1st87
1st87's Avatar
Me too!
Old 08-04-2010, 08:30 AM
sailorsteve
Support Corvetteforum!
sailorsteve's Avatar
It's not too difficult- a little messy cleaning the old w/s out of the retainers (keep a shop vac handy) and the adhesive for the new strips can make a mess, too, good idea to cover the surrounding areas with newspapers or something when you're gluing. Best glue- 3M #08008.
Old 08-04-2010, 09:59 AM
pianoguy
pianoguy's Avatar
Use the 3M weatherstripping remover to get the glue out of the channels - that is the most time-consuming part of the process. You'll need some kind of pry tool to remove the push pins at the ends of the weatherstripping, and at the upper corners of the windshield (don't lose the pins). I didn't use any glue on my new weatherstripping, and it seems to be working fine (over a year now). Use a popsicle stick or wood shim to pop the new weatherstripping into the channels.
*edit*
I would recommend not doing the A and B pillar weatherstripping the same day - do one or the other, then reinstall the top and let it sit overnight, and then do the other the next day. You may need to adjust the top brackets a bit if it is hard to reinstall.
Old 08-04-2010, 01:15 PM
mfi
mfi's Avatar
Depending on which brand you bought..it will either fit right ...or not.
Old 08-04-2010, 01:20 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
This may help you guys!!
http://forums.corvetteforum.com/c4-g...tic-doors.html
Old 08-04-2010, 01:29 PM
uptown193
uptown193's Avatar
Hey guys, no offense but the SEARCH button works miracles in situations like this, you should utilize it.
It is a very easy but time consuming project.
http://forums.corvetteforum.com/c4-g...ps-w-pics.html
Last edited by uptown193; 08-04-2010 at 01:35 PM. Reason: Added Socals Ultimate DIY Thread
Old 08-04-2010, 01:52 PM
socalman
socalman's Avatar
St. Jude Donor '10
But if we tell everyone to search, there'd be no threads for the dogs and cats to play in.
Old 08-04-2010, 02:52 PM
PLRX
PLRX's Avatar
2017 C4 of Year
Normally, nOObs do not know about the search
Old 08-05-2010, 01:19 AM
darkstallion_69
yeah im not a NOOB i prefer just to ask. at the same time it helps other people immediatly see the topic at hand. Like the first 2 that posted that are interested.
Old 08-05-2010, 03:27 AM
uptown193
uptown193's Avatar
Your not a noob, member since May of 09 but in any case God gave us brains and in these brains we use common sense thinking.
I just did mine myself also after I was quoted $400 for the install. I was nervous to do it but trust me DO NOT be scared/nervous. It is very easy to install it not even funny. First buy some 3M adhesive/bug/tar remover. Then remove the all the retainers. Find something that fits in the retainers and up in the corners of them so when u spray the 3M and let it soak for awhile scrape all the old adhesive off. This will take hours to do for all the retainers. In total there about 6 retainers I think. My front windshield retainers were not bad so i left them on. Then when installinng the retainers some people like to put the black adhesive or some 3M double sided rubber stripping on but I did not to that. It is up to you. Then screw in retainers. Buy a popsicle and eat it and use the sticks to help you wedge in the new stripping in the corners of the retainers. Start with the corners. I also did not use any adhesive except for the end pieces where the push pins go and wa-la, all done. The hardest part was cleaning the retainers. But for the rear hatch you have to pop out those clips that hold the hatch up, I cant think of what they are called now, brain freeze. Other than that is was easy. Be patient and take your time. Good luck.
Some pics for you:
Done:
Old 08-05-2010, 03:46 AM
darkstallion_69
ahh yes nothing like new weatherstripping (looks good in the pics). Cant wait to do mine. Thank you sir for the info.
Old 08-05-2010, 04:00 AM
SQUIRMIN VERMIN 84
SQUIRMIN VERMIN 84's Avatar
Location: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
I use the search too but sometimes it pays to field the question on the forum as someone may know of a better tool or newer adhesive or other product that has become available after the search links were archived.
UPTOWN, great description of methods you used! the pix help a lot too.
Old 08-05-2010, 10:49 AM
PLRX
PLRX's Avatar
2017 C4 of Year
I never called you a nOOb, just learn how to use this forum.
Old 08-05-2010, 12:14 PM
uptown193
uptown193's Avatar
Old 08-05-2010, 12:16 PM
uptown193
uptown193's Avatar
Your welcome. I wold not look forward to doing it. It is not fun job, lol.
Thank you, I try.
To How to do the weatherstripping?
Old 08-05-2010, 01:45 PM
Vette Jockey
Roadster Madness. 😠
Vette Jockey's Avatar
Received 1,510 Likes on 864 Posts
St. Jude Donor '13, '20-'21
Great masking job. I bet that took a bit of time
Old 08-05-2010, 03:27 PM
thedudeman321
thedudeman321's Avatar
Hey uptown193,
What brand weatherstrip did you use?
Old 08-06-2010, 12:14 AM
91red vet
91red vet's Avatar
I agree with the above comments about time -- you need lots of it and don't rush it. Your kit will probably not include the door to dash seal -- that was in the worst condition on my 91. I bought my w/s from MidAmerican and it did not include the body pins. After MUCH searching I did find the correct pins and if you need to get them locally this is what i found.
Big pins for the dash to door seal i got from my local GM dealer. $1.05 for two. They have them all, but the others are fairly expensive.
Pins for the top of the windshield w/s came from Advance Auto Parts #963-075. This is an assortment of pins, but there are 3 of the correct pin that you will need 2 of. You may need to drill out the hole by about 1/32.
The smallest pins came from NAPA #665-1987 package of 30 - you will need 6 pins. The package was around $3.50. These are for the bottom of the windshield w/s (4) and top of the roof w/s (2).
Hope this helps. Good luck and have fun!!
Quick Reply: How to do the weatherstripping?
