Tach filter
Tach filter
I have a 91 convertible with a tach going haywire and got a new tach filter. Where physically does it go? Got the schematic, but it's not clear where it goes. Help!!!! Thanks!!!!
I've read the tach filter is rarely the problem.
After much reshearch, this is what I did.
DISCONNECT NEG BATTERY TERMINAL.
Drop your drvrs hush panel,
drop your steering wheel( 2 bolts)
Remove dash cluster (4 screws)
Remove tach circuit board.
Go to radio shack and buy either 1 200K 1/2 watt ohm resistor, oR two 100K 1/2 watts reistors and solder then together for a total of 200kohms.
Solder this from Pin 4 to pin 10 on the board. The pic shows front, easier to do at back of board. Use shrink tubing or electrical tape as not to short.
Cut, or scratch thru the exsisting path between the "old" route between pins 4 and 10.
Reinstall reversing instructions.
It's really not that hard to do.
Good info here
http://www.thirdgen.org/techboard/el...ter-fix-3.html
Not "my" pic.
It took me quite a while to find this info..good luck.
or, you can send it out for $275-400 and have someone else do it.
Or you can swap a new cluster in.
You'll get with-in 50-75 rpms.
He has sent you a private message, likely some info on your problem. Look in the upper right area of your computer screen, you should see a small window saying welcome ewdickerson followed by a notice you have a PM. Click on "Your Notifications".
90/91 cars have well documented problems with the cluster itself.
New filter seldom fixes problem
http://forums.corvetteforum.com/c4-g...1990-vert.html
http://www.thirdgen.org/techboard/el...meter-fix.html
PM sent.
Good info here
Not "my" pic.
Good info here
Not "my" pic.
SERIES connection looks like (WHAT YOU DO WANT TO DO IF YOU BUY THE TWO 100K RESISTORS):
PARALLEL connection looks like (WHAT YOU DON'T WANT TO DO)"
