Looking for info on ZF 6 speed.
Old 05-27-2010, 04:15 PM
1989 406's Avatar
Default Looking for info on ZF 6 speed.
Do people like it? I drove one and I had liked it. I have heard some people stay away from them. Are they reliable?
Old 05-27-2010, 04:39 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I like mine, its time to replace the clutch though.
Only problem is the dual mass flywheel is scacer than hens teeth.
zfdoc has lots of info on his site about them!
Old 05-27-2010, 05:41 PM
Klondike
Klondike's Avatar
Love mine, but like said above, clutch is the kicker with these. Replacement with anything but the stock ( BIG $$$ ) type dual mass makes them rattle at idle like a coffee can full of marbles. It doesn't hurt them, but it is irritating and embarrassing to have a nice car like a Vette make that noise.
Old 05-27-2010, 05:48 PM
jeffs40thgtp
jeffs40thgtp's Avatar
i really like my zf, just got a new clutch kit from tpis.. i said f! that duelmass flywheel and got a conversion kit that take the stock 49lb flywheel to a 12lb and no more external slave, kit come with internal slave that hooks to the lines with no problem... it was 930$ form tpis and the kit is from ram. and i also got the B&M short throw for it to, i cant wait to put it in
Old 05-27-2010, 06:02 PM
Z-07 freak
Z-07 freak's Avatar
Location: Why are there squished peanut butter cups in my underware?
1,000 times better than that mexican made crap 6-speed in C5s & C6s.
Old 05-27-2010, 07:02 PM
zr1fred
zr1fred's Avatar
They're great! (until they break).
Old 05-27-2010, 07:11 PM
RedLS1GTO
RedLS1GTO's Avatar
Imagine that... somebody asks specifically about a C4 and within 5 replies there is a C5/C6 bash.
I've yet to see a single advantage from the ZF in my 96 to the M12 in the 02Z sitting beside it.
Old 05-27-2010, 07:25 PM
SJW
SJW's Avatar
Received 1,389 Likes on 920 Posts
The ZF is tough as nails. There are many people who have been putting serious torque through these gearboxes for years without any problems. Obviously, it's possible to damage one, but generally speaking they're quite rugged. I have them in both of my C4s, and couldn't be happier with them. I do wish that sixth gear wasn't quite as tall as it is, but a set of 4:10 gears in the diff would mitigate that to a large extent.
The Dual-Mass flywheels are getting hard to find, and were always expensive. They are also very heavy. Many have reported here that switching to a lightweight aluminum Single-Mass unit tends to cause a lot of gear rattle at idle, and tends to make the car more challenging to launch from a dead stop in everyday driving, but of course it will also allow the engine to rev up faster because there's less rotational mass to accelerate. Many others have reported that switching to a steel Single-Mass unit made for a good compromise between the extremes of the DMF and the aluminum SMF. The steel unit weight comes in somewhere between the DMF and the aluminum SMF, which makes launches less problematic, and helps to keep the gear rattle at bay, compared to the aluminum SMF.
Note that I have no personal experience with this, but when the time comes, I plan to switch to a steel SMF after hearing what others have had to say about the whole subject.
Live well,
SJW
Old 05-27-2010, 07:35 PM
Z-07 freak
Z-07 freak's Avatar
I'm not bashing C5s or C6s. Just the POS mexican trannys in them. Get it straight.
Old 05-27-2010, 07:42 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Strong and reliable, just make sure the hydaluics are in good shape.
ZF trannies are more expensive than avg. to rebuild but any trans shop that works on German ZF boxes can do one;no need to fork up big bux to a Vette only trans guru.
Old 05-27-2010, 07:52 PM
RedLS1GTO
RedLS1GTO's Avatar
Other than shift forks in certain models... what is a POS with them? I've seen a lot of people put a whole lot of hard miles on them and I have NEVER seen a C5/C6 6 speed transmission fail.
Old 05-27-2010, 07:58 PM
cv67
cv67's Avatar
St. Jude Donor '05
Seen a bunch of C5 trans go seems like 3rd is a weak spot but the LTx T56 dont like it either for some reason. Good trans though overall.
There are upgrades to overcome like anything else just dig into those pockets. Cant wait til I hurt mine to get a custom 6th gear and Z06 gearing set.
Old 05-27-2010, 08:09 PM
RedLS1GTO
RedLS1GTO's Avatar
I will say that every C5 trans that I have ever seen abused was a M12 (Z06) so I can't really speak for the MM6. The only repeat offender I have seen is the 2nd gear synchro doesn't like hard downshifts.
Old 05-27-2010, 08:23 PM
Snakecharmer383
Snakecharmer383's Avatar
Love my 6spd
Love my SPEC clutch (so far)
Love my SPEC Alum. Flywheel (so far)
B&M Ripper shifter - kinda notchy and haven't banged through the gears yet so... (TBD)
Old 05-28-2010, 04:34 PM
1989 406's Avatar
Great info. It is appreciated. I guess while on the topic how about the 4+3 in the older C4s?
Old 05-28-2010, 05:53 PM
zr1fred
zr1fred's Avatar
It's everything the ZF6 isn't.
Old 05-28-2010, 08:45 PM
jaa1992
jaa1992's Avatar
St. Jude Donor '12
The 4 is OK, its an old doug nash.
The +3 not so good when you throw lots of torque and HP at it
To Looking for info on ZF 6 speed.
Old 05-31-2010, 07:49 AM
TJM
TJM's Avatar
Dick!? , fill out your ID!! for all we know your an 11 year old girl?
The ZF weighs a freaking ton. Seriously, it's heavy. The thing is made for a truck [ true story].
The 4+3 is light by comparison, old tech, and strong. 4+3 is a T10 with a mini power glide attached. The "4" part rarely breaks.
The +3 part is as big a pain to fix as a ZF.
Not making a commercial here, but give some thought to aftermarket stuff if your planning on keeping the car and will be putting any stress on it [ as in racing].
TJM,
Old 05-31-2010, 11:54 AM
1989 406's Avatar
TJM,
Not sure how to read into Dick!?
Old 06-01-2010, 09:59 AM
drmrman
drmrman's Avatar
I have a DM Flywheel with 48 thousand miles on it forsale if anyone is interested!?!?!?
Quick Reply: Looking for info on ZF 6 speed.
