How to remove silicone
Any good silicone removers, tried wd40, adhesive remover, heatgun, goo gone,being a real bitch.
Took off driving light grills and dude that put them on, used a wack of silicone.
Any replys would be greatly appreiciated.
I think Acetone will disolve it but before you use it, the old warning on the carpet cleaner is in order - test on an inconspicuous area. If its a metal part acetone shouldnt be a problem but if its plastic or fiberglass i think you risk "melting" the plastic. hope that is helpful, only thing I can think of off the top.
Found this McKanica Remover. no experience with it but you might look over the details at the link. http://www.amazon.com/Mckanica-0351-...outThisProduct
Friction.....we used it to "glue" foam into concrete molds. I tried many different things to get it off....even oxygen acetylene torch...no go. Ended up using razor blades to get most of it off, then rubbed with rags to create friction to roll it off.
