What type of oil?
Old 04-20-2010, 12:49 PM
AC13
AC13's Avatar
Default What type of oil?
The indicator light says it time to "Change Oil".
What is the right oil to use for a 95?
Old 04-20-2010, 12:58 PM
j-vette
j-vette's Avatar
St. Jude Donor '10
IB4Twarofwordsonwhatoilisbetter
Old 04-20-2010, 01:00 PM
surfer92
surfer92's Avatar
Motor oil always works for me!!
This and a couple others will get you a different answer from just about everybody.
Go with a brand you like, for low mileage 5w-30 and 10w-30 for high.
Mobil 1 Synthetic came in the cars.
Glock 23C
Glock 23C's Avatar
Mobil 1 5W-30. That is what my 95 came with from the factory. 10W-30 will also work, per the manual. There might be a Mobil 1 sticker under your hood near the front.
Old 04-20-2010, 01:07 PM
AC13
AC13's Avatar
Thanks for the help.
I was waiting for some wise guy to write "olive oil" or "Wesson oil.
AC
Old 04-20-2010, 01:23 PM
surfer92
surfer92's Avatar
AC
Well the question just about warrented it.
Old 04-20-2010, 01:25 PM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
probably says right on the oil filler cap
Old 04-20-2010, 01:49 PM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
And don't forget to reset the "Change Oil" light.
It won't automatically go out just because you change the oil.
Instructions are in the owner's manual.
In case you don't have one, you can download a '95 manual here:
http://www.gmpartshouse.com/download...95corvette.pdf
Old 04-20-2010, 02:23 PM
1991-C4
1991-C4's Avatar
AC
So its either:
OR
Old 04-20-2010, 04:23 PM
Mrs. glass car
Mrs. glass car's Avatar
The directions are printed on your oil filler cap.
Old 04-20-2010, 04:31 PM
Sweet 90
Sweet 90's Avatar
Took me a second to get Florence.
Nice work nOOb, I like your style Always use another smartazz here
Originally Posted by 1991-C4
So its either:
OR
Old 04-20-2010, 05:49 PM
skybolt31
skybolt31's Avatar
For your car, the manual says to use oil that meets the GM4718M specification. I was a chemical engineer and used to write specifications for a living but I cannot tell you what is so special about oil that meets that spec or why GM seems to think that an LT1 motor needs it and others don't, but it doesn't seem like a place where I am going to out smart them by using something that doesn't meet the spec. There is readily available oil out there at a modest price that does meet it, so that is what I use. So far, I have found Mobil 1 5-30 and Penzoil Platinum 5-30 and 10-30 meet the spec, many of the variants of Mobil 1 do not meet the spec.
Anyway, that will conclude my oil rant..............
Old 04-21-2010, 12:11 AM
Pwnage1337
Pwnage1337's Avatar
Urine works nicely.
Old 04-21-2010, 12:18 AM
mike100
mike100's Avatar
Since the LT1 doesn't come with an oil cooler option, the oil has to meet GM4718M specifications.
regular Mobil1 5w-30 meets this as do a few others.
If this post is in jest, then I'd recommend resetting the oil life reminder light- which automatically makes the oil good again for about 5000 miles
Old 04-21-2010, 12:55 AM
Z-07 freak
Z-07 freak's Avatar
Location: Why are there squished peanut butter cups in my underware?
Old 04-21-2010, 04:37 AM
enventr
enventr's Avatar
Old 04-22-2010, 11:56 AM
j-vette
j-vette's Avatar
St. Jude Donor '10
Originally Posted by Pwnage1337
Urine works nicely.
Didn't urine kill Natalee...?
To What type of oil?
Old 04-22-2010, 12:21 PM
Swift_Striker
Swift_Striker's Avatar
since you have a roller cam engine it wont be too picky on the brand but yes mobil 1 came in your car so you might as well use it.
Flat tappet cam engines are different because the lobe drags across the lifter you need an oil with more zinc in it to protect the cam and many oil companies have reduced their zinc content significantly. My last oil change cost me $100 because I used Amsoil, one of the manufacturers that still has a decent zinc content.
but that's not for you, you're fine with Mobil 1.
Old 04-25-2010, 11:55 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
Originally Posted by Swift_Striker
... My last oil change cost me $100 because I used Amsoil, one of the manufacturers that still has a decent zinc content.
Swift Striker,
Are you a AMSOIL Preferred Customer Program member? If not, drop me a PM before you order next time and I can save you about 25%.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Old 04-25-2010, 01:59 PM
MidShark
MidShark's Avatar
Here is a link to GM's list of high performance oils that meet the GM4718M specs:
http://www.gm.com/corporate/responsi...ngine_oils.pdf
Quick Reply: What type of oil?
