Headlights Malfunction
Old 10-07-2009, 06:42 PM
kyle37
kyle37's Avatar
Default Headlights Malfunction
89 Corvette headlights will not fully seat in the "on" position. They free-wheel. I understand 3-bushings sold by Eckler's can correct that. But for now, how can I manually secure those "on?" Thank you.
Old 10-08-2009, 11:49 AM
tomtom72
Support Corvetteforum!
tomtom72's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
I'm almost positive the 89 & the 90 ( what I have ) instructions are the same for the manual opening of the lights. On the motor there is a **** at the top, turn it till the head lights flip into the "up" or "lights on" position.
What I don't know is if the bushings are shot, will the light stay in the up position.
Old 10-08-2009, 05:53 PM
1bdvet
1bdvet's Avatar
Received 4,499 Likes on 3,586 Posts
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Instructions for replacement.
http://home.comcast.net/~zrjuan/headlight.html
Old 10-08-2009, 06:09 PM
Vette Jockey
Roadster Madness. 😠
Vette Jockey's Avatar
Received 1,507 Likes on 861 Posts
St. Jude Donor '13, '20-'21
[QUOTE=1bdvet;1571756967]Instructions for replacement.
QUOTE]
Is this as straight forward as it seems? I am going to try this this weekend. I bought a brass gear with the buffers from Mid-America. Would lithium grease be good to use, since it will be brass on brass, or should I use something different? Thanks for all the help from all the people, on all the threads I have read on this subject
Old 10-08-2009, 08:11 PM
walter schweigert
walter schweigert's Avatar
I did mine about a month ago. Used lithium white grease. The old plastic gears still were OK, but I replaced them with new plastic ones anyway. The three little round bushings were all that they needed. Keep your gear in the package untill you know that you need them, and if not send them back.
Good luck.
Old 10-09-2009, 01:55 AM
Vette Jockey
Roadster Madness. 😠
Good luck.
Old 10-09-2009, 02:15 AM
CoolVette86
CoolVette86's Avatar
Location: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
The headlight assembly is easy to take off. Just take your time and be patient. Be sure to clean out all the old grease, loose pieces, etc.
Also, adjust the brass pieces that mechanically stop the motor once it's in the open or close position. You'll know what I'm talking about once you open up the assembly. Good luck!
Old 10-11-2009, 09:51 PM
Vette Jockey
Roadster Madness. 😠
Good luck.
I used the white lithium grease. I used the Mid-America Brass Gear. You were right, the bushing were dust. I had to press fit the bushings into the gear since they did not fit right. The gear looked fine, I will keep it for an emergency.
Thanks to everyone that has done a thread, it did help.
Old 10-12-2009, 10:10 AM
kyle37
kyle37's Avatar
Thanks to all. especially the comments on manual adjustment...I did that and it worked fine. After I order & receive the bushings, I'll let you know what happened. Again, thank you.
Old 11-09-2009, 02:41 PM
kyle37
kyle37's Avatar
Default Headlight Problem
Good luck.
Walter
Thank you and the others for your input. It was just the right thing to do. I got lithium white grease. Then the 3-plastic bushings from Eckler's (around $5). The old bushings were just powder. Probably should have purchased the brass gears too.
Again thanks all. Walt
To Headlights Malfunction
Quick Reply: Headlights Malfunction
