AC Performance
Old 06-19-2018, 12:17 AM
LT4Rich
LT4Rich's Avatar
Default AC Performance
1996 Coupe
Just wondering if while AC is on and dash vent mode selected, is it normal to get a slight airflow out of the defrosters and floor vents. Otherwise everything else regarding the AC seems to be normal?
Thanks!
Old 06-19-2018, 08:24 AM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
Originally Posted by LT4Rich
1996 Coupe
Thanks!
​​​​​​​How much is a slight amount ? A better way to look at it might be to try and decide if you have a normal amount of air coming out the desired vents. If so then I wouldn't worry about it.
Old 06-20-2018, 12:25 PM
LT4Rich
LT4Rich's Avatar
Can some of you check your own coupe and see if you have the same condition. Please indicate the year of your vehicle.
Old 06-20-2018, 03:34 PM
Fastnail
Support Corvetteforum!
Fastnail's Avatar
St. Jude Donor '16
My 96 coupe does the same thing, not very much air comes thru them but there is some. Hope this helps.
Old 06-20-2018, 06:07 PM
LT4Rich
LT4Rich's Avatar
Thanks Fastnail for your input. I’m trying to determine if the system was designed this way or if there is a slight malfunction involved.
Old 06-20-2018, 09:10 PM
OH THREE Z
OH THREE Z's Avatar
2018 C4 of Year Finalist
96's have a poorly designed componet that allows vaccum lines to collapse thus kerping the vents from operating properly...
consider yourself lucky that you have any forward blowing air. i have 2 96's... my LT4 only has air coming from the floor and windshield vents. My GS will eventually switch to the forward dash vent after driving it for a few minutes
search the web for this exact problem and you can read more about it as well as the fix
To AC Performance
Quick Reply: AC Performance
