Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-31-2009, 09:28 PM   #1
dchoran
CF Senior Member
dchoran's Avatar
Location: Appleton, Wisconsin Boston originally - North End
Default Glass top scratches - how to fix??????????
I just got a nice '84 acrylic smoke top from the salvage yard at a decent price.
BUT, as expected, there are a few "pencil thin" scratches on the top.
What is the best way to fix????????????????
Everything in the stores seems to be paint/clearcoat related.
Simonez Fix Up Pro???
Razor sharp Sharpie???
Nu-Finish Scratch Doctor????
Rubbing compound????
I know somebody out there has THE solution!!!!!!!!!!!!!!!!!!!!!!!!!
THANKS in advance.
Dave H. Appleton, WI
dchoran is offline   Reply With Quote
Old 08-01-2009, 01:19 AM   #2
c4sailor
CF Senior Member
c4sailor's Avatar
Search the tech posts, I seem to recall that I saw one in the last year to 18 months that had the procedures with pictures. Involved sanding at progressively finer grits and then polishing.
Found it http://forums.corvetteforum.com/show....php?t=2020059
c4sailor is offline   Reply With Quote
Old 08-01-2009, 05:35 AM   #3
toptechx6
CF Senior Member
toptechx6's Avatar
For light scratches I've had good results with a product from Mequire's called PlastX.
toptechx6 is offline   Reply With Quote
Old 08-01-2009, 09:58 AM   #4
dchoran
CF Senior Member
dchoran's Avatar
Quote:
C4Sailor - thanks for the link - that looks like a serious refinish.
My top is crystal clear - no cracks, no hazing, no delam......
All I am trying to do is remove some LIGHT scratches.
Toptech:
Plastx - wipe on / wipe off???
THANKS.
Old 08-02-2009, 10:41 AM   #5
dchoran
CF Senior Member
dchoran's Avatar
Anybody ever try Nu-Finish SCRATCH Doctor on a clear roof???
Original GM Alma Coat top.
Old 08-02-2009, 03:14 PM   #6
c4sailor
CF Senior Member
c4sailor's Avatar
Yes. and Maguires Mirror Glaze cleaner for heavier scratches. You can also go by the local Fixed Base Operator (FBO) at your local General Aviation Airport and see what they have for use on light aircraft windscreens (plexiglass/lexan). Their mechanics may be able to give you some tips on polishing out the scratches.
Old 08-04-2009, 05:51 PM   #7
GREENC493
Junior Member
My top was scratched bad. I used a 220 grit to smooth it out and worked up to 1000 grit and then polished it out with a 3M rubbing compound and finally a polish. This took hours it does not polish fast. The process is alot like buffing paint only the material is alot tuffer so the results are slower. If the scratches are fine, start with a high grit and go higher. The higher the grit the faster the buffing will be or just use a high speed buffer and compound first to see if you can skip the sanding. Do not stay in one spot to long because of heat and do not use harse cleaners on it. Soapy water works fine.
GREENC493 is offline   Reply With Quote
Old 08-04-2009, 06:33 PM   #8
dchoran
CF Senior Member
dchoran's Avatar
IMHO, PlastX doesn't work worth a crap on anything - did absolutely nothing on light scratches.
Anybody try Simoniz Fix-It Pro on their tops???????????????
Specifically that "pen" that is advertised like a miracle. https://www.simonizfixit.com/flare/next?tag=os|sm|go "god rest his soul billy"
Looks like Autozone sells 'em for ~ $15.
Thanks Dave H. (trying to do it the "easy" way)
Old 08-08-2009, 08:54 PM   #9
dchoran
CF Senior Member
dchoran's Avatar
An ultra super fine black Sharpie works GREAT to cover up the scratches!!!! The top looked awesome.
Until you look up from the inside - when it looks like the arm of one of those self mutilating razor fettish's scars
Reload this Page Glass top scratches - how to fix??????????
Tags
1994, 2005, acrylic, c4, c5, compared, corvette, doctor, fix, glass, panel, pro, roof, scratch, scratches, store, top
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Odered '06 Vette Today! Question on trade in. c5vette73 C6 Corvette General Discussion 26 08-14-2005 06:16 PM
Update on repaint Steel Blue 91 C4 General Discussion 32 02-21-2005 08:03 PM
Is there a way to fix minor scratches in lenses? iveka C3 Tech/Performance 13 12-30-2003 07:44 PM
What do you guys think about this Z? Dr. Evil C4 ZR-1 Discussion 32 12-13-2002 06:59 PM
Back from the body shop w/ ZR1, pretty good news VetteBabe1 C4 General Discussion 45 03-14-2002 01:34 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
