emergency hood release cable - EASY with pics
Old 06-24-2012, 09:33 PM
  #61
BSenzina
BSenzina's Avatar
Originally Posted by rickneworleansla
I think I'm going to get me this tonight from Walmart. Whats the best way to secure it to the latch?
This is EXACTLY what I did ! ! SOOOOO SIMPLE ! ! ! Thanks for the solution ! !
Old 06-25-2012, 01:52 AM
  #62
ZR-71
ZR-71's Avatar
St. Jude Donor '15
Originally Posted by tntwolt
for some reason i can`t open the pics, i get a red "x". any help with this?
Check back later. Maybe the server for the pics is down
Old 06-25-2012, 12:48 PM
  #63
tntwolt
tntwolt's Avatar
found a pic in thread, now i know what its supposed to look like. have not yet hooked up withany C4 guys to share info about our cars
Old 07-04-2012, 05:45 PM
  #64
Sworn
Sworn's Avatar
St. Jude Donor '12
Can someone upload new pictures of this Mod? The original ones are dead.
+1 I would like to see some proper pictures as well!
Old 07-04-2012, 06:08 PM
  #65
Bandit's C4
Bandit's C4's Avatar
Central PA Events Coordinator
St. Jude Donor '12-'13
Originally Posted by Railroadman
Yes it's an old thread but a helpful one - hopefully the moderators will keep it open since we have a whole lot of new C-4 owners who have not yet done this.
Others may have better pics but here's mine - color coordinated to the car no less!
great color, too
Old 07-04-2012, 07:27 PM
  #66
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
It is a great idea.
Old 07-04-2012, 09:08 PM
  #67
pkazsr
pkazsr's Avatar
Cruise-In X Veteran
St. Jude Donor '09
Originally Posted by pkazsr
:o I have all the parts to install the release in my tool box. They have been in there for 2+ years.
Three years later, (Just like this thread), the parts are still there.
Old 07-04-2012, 09:25 PM
  #68
Railroadman
Railroadman's Avatar
Received 5,009 Likes on 2,528 Posts
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
We're holding the thread open until you finally do it!
Hey, maybe you never will need them. Or, maybe the old one will break just as you try to open the hood to put out that fire you just discovered!
Old 07-04-2012, 09:29 PM
  #69
weaselbeak
weaselbeak's Avatar
Default emergency release
Here's some pics of how I did mine. Same basic plan as others but i reconfigured my attachment point to beef it up. Cut some metal line to run my cable through.
Happy 4th
Eagle51 (04-19-2023)
Old 07-04-2012, 09:49 PM
  #70
Sworn
Sworn's Avatar
St. Jude Donor '12
^ Great pics! Thanks!
Old 07-05-2012, 03:06 AM
  #71
pkazsr
pkazsr's Avatar
Cruise-In X Veteran
St. Jude Donor '09
I have 2 problems about getting it done.
1) When I think of it it is 3:00 am
2) Usually I believe if it aint broke don't fix it. When I try to do preventive maintenance on the Vette a $50 fix turns out to be a $500 repair.
Beeblebrox237 (03-20-2022)
Old 07-05-2012, 08:27 AM
  #72
jimmymack
Support Corvetteforum!
jimmymack's Avatar
St. Jude Donor '09-'10-'11,'13-'14-'15-'16-'17-'18-'19-'20-'21,'22-'23-'24
Suggest you stay at a Holiday Inn the night before.
Old 07-31-2012, 07:33 AM
  #73
Raptor_1
Raptor_1's Avatar
Odd, I don't see any photos in the OP's post.
Old 07-31-2012, 10:02 AM
  #74
Railroadman
Raptor that's because this is a 3-year old thread and probably the OP has taken them down from Photobucket or whatever site they were on, or maybe he changed accounts.
Usually the forum has a "45 day rule" which says if a thread is that long without a post, you start a new one instead of reviving the old. In this case the mods have (wisely IMHO) allowed the old one to stay alive as it contains so much good info.
Welcome, and if you are a C-4 owner you might want to think about doing that modification as some day, some where, the old one will break.
Old 07-31-2012, 10:55 AM
  #75
John.87
John.87's Avatar
this seems like an inexpensive, smart mod to do.
Old 07-31-2012, 11:43 AM
  #76
Railroadman
John you are right. These are old cars and it's only natural that things wear out. It's common for the hood release cable to break and there's seldom a time when it's convenient for that to happen. But I'm not on a soapbox, I had it on my "to do" list for a couple years. What finally pushed me off the fence was finding that cable in my garage, left over from a pool cover, and the color about perfectly matching the Vette. At that point I got excited and did the work!
Old 08-02-2012, 08:15 AM
  #77
Raptor_1
Raptor_1's Avatar
The cable retainer on my car doesn't look like the the ones in the photo.
It doesn't have that extra slot.
I used a couple pieces of duck decoy cord about 15" long, slid the one end through the clip beside the original cables, tied a couple of knots to secure them and tied a loop in the other end that lays under the wipers.
Does the job just fine.
To emergency hood release cable - EASY with pics
Old 01-10-2014, 08:19 AM
  #78
smitty43p
1st Gear
smitty43p's Avatar
Default Corvette hood release
Originally Posted by ottawabarber
My hood release cable has worked fine since I bought my 88' but many threads here have mentioned horror stories of a broken cable and not being able to get the hood open.
One great solution that has been discussed here was a set of emergency release cables in the wipers area.
I decided to make a pair for mine and thought I would take some photo's to share for people like me who find a photo or drawing often times more understandable than only words.
Total cost was $7.00 !! 1/16" wire cable at .69 cents a foot, and one package of Cable Clamps and Stops and state tax. The clamps are aluminum and need to be hit with a hammer against a steel bar to crimp the cable properly.
Here is the location of the existing factory installed cable. Adjacent to the cable connection is a small opening that allows the 1/16" cable to go through.
This next one is a close up of the clamps I used.
Since I was using 1/16 cable I decided to drill a 1/8" hole through the rubber guard below the wipers to allow free movement. I tried to make the cable lay as straight as possible. This photo is the cable before being cut and the stop being put on.
These next two photo's show the cables completed, and the last is a close up of the connection. I intend to paint them black to make them blend in and not be so noticable.
Total time 30 minutes (a guy has to sip some malt beverage on a job like this )
I now have a great piece of mind knowing if my primary cable fails, I can still gain access to the underhood to fix it.
Hope this is helpful for some of you
Larry
Old 08-10-2014, 06:50 PM
  #79
lectroglide
lectroglide's Avatar
I used some steel fishing leaders on both sides and crimped the loops at the ends, then run the other ends to the middle of the hood on each side and crimped some loops again for something to pull on, I dare that hood cable to break!!
Old 08-10-2014, 07:32 PM
  #80
ghoastrider1
ghoastrider1's Avatar
the only thing to beware of is the e-cable getting caught in the hood pin locater hole. I used mine e-cable a few times, then the :no -start condition happened. Pulled the cables. . drivers side popped the hood. Pass side was trapped in the locator hole, broke when I put the muscle to it. Had to buy the "tool" to pop the hood. 25 bucks.PIA to use. Got it to finally work. New hood cables on the way and bought some stranded wire this time for the e cables.. Oh, fixed the fuel pump problem too,lol.
Quick Reply: emergency hood release cable - EASY with pics
