Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-21-2009, 08:36 PM   #1
Johnfur
CF Senior Member
Default How to remove steering wheel on a 1990
Horn quit blowing.
There are 3 fuses associated with the horn and security system.
1. All 3 fuses are good, both in fuse pannel and one up under the
passenger side dash.
2. Horn will blow when in securith mode.
Therefore, there is battery to horn relay.
There is battery to CCM computer, horn blows intermittently.
3. Horn will not blow from sterring wheel button.
4. Therefore, I assume I have a defective horn button.
5. How do you remove sterring wheel to expose horn button ???
Thanks John
Johnfur is offline   Reply With Quote
Old 05-21-2009, 09:20 PM   #2
pipe
CF Senior Member
Send a message via AIM to pipe
Before you do anything DISCONNECT THE BATTERY and let it sit ten minutes. Then remove the 2 Torx bolts from behind the steering wheel. That will remove the airbag. Disconnect the small yellow plug from the air bag unit and set it aside. Look for the wire coming from your horn buttons. It should go into a white plastic connector (looks like half of an inline fuse holder) The wire from your horn buttons has a spring on it and a black plastic connector. This turns a quarter turn and locks into the white plastic piece that is inside the column. This part gets brittle and breaks over time and the wires from your horn buttons won't make contact anymore. You will see a round plastic piece with a spring in it that has to do with the airbag. Push down on this and remove the snap ring and slide this off the steering shaft. Remove the small wire clip on the shaft. Now you will need the steering wheel puller. Pull the wheel and behind it you will see the white plastic piece (turn signal/horn cam) it's called. It's about $10 from auto zone. Install it and put everything back in reverse as you took it off. Make sure the steering wheel is lined up with the tires facing straight. Push the horn wires with the black connector and spring into the new connector and twist 1/4 turn to lock. GOOD LUCK Pipe
pipe is offline   Reply With Quote
Old 05-21-2009, 11:37 PM   #3
jrzvette
CF Senior Member
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
In addition to disconnecting the battery, I suggest you also pull the fuse for the airbag before doing anything, just to be safe.
jrzvette is offline   Reply With Quote
Reload this Page How to remove steering wheel on a 1990
Tags
1984, 1990, 1996, 90, c4, column, corvette, forum, pull, removal, remove, steering, sterrin, wheel, whell
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
