Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C4 Corvette Discussion not covered in Tech Sponsored by
Marc Heitz Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-17-2009, 01:20 PM   #1
betyelou
CF Senior Member
betyelou's Avatar
Default MSD or optispark
Looking for your opinion on what you think is the best. Vette is a 1996 CE LT1. Should I go with the MSD Pro Billet Dist. at $519.00 or the Accel LT1 Performance Dist at $299.00. Or AC Delco at $349.99. Or perhaps there is a better make out there.Thanks.
betyelou is offline   Reply With Quote
Old 04-17-2009, 02:42 PM   #2
CAJUN C4
CF Senior Member
CAJUN C4's Avatar
I've never had,fortunatly,have to buy one.I've heard the MSD is very ggod.
CAJUN C4 is offline   Reply With Quote
Old 04-17-2009, 03:32 PM   #3
jrzvette
CF Senior Member
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
Your 96 has the second generation, vented opti, which is a big improvement over the original design. But if you compare the MSD (and Dynaspark) you'll see that they are much better units than OEM. Having said that, a lot depends on your budget; they'll both require the same amount of work (or $$ if you have someone do it for you) to install.
jrzvette is offline   Reply With Quote
Old 04-17-2009, 09:04 PM   #4
papafrancisco
CF Senior Member
papafrancisco's Avatar
In what ways are they better?
papafrancisco is offline   Reply With Quote
Old 04-18-2009, 01:11 AM   #5
deerra
CF Senior Member
deerra's Avatar
I went with MSD and have no regrets. Very well made. Also installed a new MSD coil while I was doing the work.
deerra is offline   Reply With Quote
Old 04-18-2009, 08:37 AM   #6
betyelou
CF Senior Member
betyelou's Avatar
With all the problems with the C4 opti that you read about on the forum, I thought that there would be more opinions. Thanks for input so far. Still not sure which way to go.
Old 04-18-2009, 10:29 AM   #7
pianoguy
CF Senior Member
pianoguy's Avatar
I haven't heard much good about the Accel unit. If you are interested in the MSD, get a quote from epowershops.com. I installed the MSD last year and it has been fine.
pianoguy is offline   Reply With Quote
Old 04-18-2009, 01:48 PM   #8
curtis74
CF Senior Member
curtis74's Avatar
How hard is it to install a new one? What specific steps are involved?
curtis74 is offline   Reply With Quote
Old 04-18-2009, 03:45 PM   #9
pianoguy
CF Senior Member
pianoguy's Avatar
Quote:
It's best to have the FSM for torque specs, etc., but here's the basic steps:
1). Drain the cooling system, by opening the petcock on the radiator, and then by removing the knock sensors on each side of the engine block
2). Disconnect the battery negative cable
3). Remove the air cleaner bellows and serpentine belt, disconnect electrical connections to MAF and water level sensor
4). Disconnect radiator and heater hoses, and remove the water pump (you may also want to remove the radiator hoses to get them out of the way)
5). Remove the harmonic balancer pulley (3 bolts) - you may want to spray some PB blaster where it mates to the hub, and also mark the pulley's position. Note that the pulley bolts must be roughly at 10, 2 and 6 o'clock in order for the opti to clear the hub. The pulley may be difficult to remove (hence the PB Blaster) - one method is to loosen the three bolts slightly, then fire up the engine briefly to see if that breaks it loose. If that fails, you can tap on it with a 2x2 from underneath and behind, rotating the engine every few taps.
6). Mark the spark plug wires and vacuum hoses, and disconnect from the opti
7). Remove the cap from the opti and mark the location of the rotor
8). Remove the opti
9). Check the seals around the opti and water pump drives, replace if necessary, and clean the water pump mounting surface.
10). Install new opti, noting rotor location - make sure it mates easily with the front cover without force
11). After plug wires, etc. are attached to new opti, install the balancer pulley (coat the mating surface with anti-seize first), connect battery and start the car briefly to make sure opti is functioning properly
12). Reinstall everything in reverse order - note - check the o-ring on the engine shaft for the water pump to see if it needs replacing. A new water pump will come with only one o-ring for the pump, so you may need to buy another. Also make sure to use thread sealant on the water pump bolts.
13). Make sure to bleed air from cooling system when refilling.
You may find that removing the belt tensioner and the coil gives you a little more room to work. Also, this is the optimal time to replace the plug wires and hoses. If replacing the plug wires, you will find that loosening the power steering pump to allow you to pull it forward a bit is helpful.
Old 04-18-2009, 09:56 PM   #10
curtis74
CF Senior Member
curtis74's Avatar
Brad,
Thanks man! Good to see that there are not too many steps involved
Good lord.........I hope to not have to do this anytime soon.
What are some of the symptoms of an opti going bad?
Old 04-18-2009, 10:18 PM   #11
Andrew
CF Senior Member
Andrew's Avatar
Brad,
Wait until you need new plug wires!!! Almost just as bad!!!
Let me know if you have troubles with the opti, I can make a trip to Columbia and pass some tools if needed. It really isn't that bad.
__________________
2003 Z06 - Atomic Orange
SOLD - 1996 LT4 - Competition Yellow Coupe / Black Interior Mods: DRM 383, NX N2O, Line Lock, and other fun stuff.
SOLD - 1996 LT4 - Mods - Exhaust
1 of 1 Competition Yellow Coupe /LT4/Gray Interior/F45
SOLD - 1979 383 4 Speed
Andrew is offline   Reply With Quote
Old 04-18-2009, 11:08 PM   #12
Cadillac Tech
CF Senior Member
Cadillac Tech's Avatar
I installed the MSD unit a year ago on our '96 and it has been awesome for 10,000 miles and counting.
Cadillac Tech is offline   Reply With Quote
Old 04-18-2009, 11:58 PM   #13
Arkybill
CF Senior Member
I put the MSD on my 94 LT1 last year (June) and it's been just great. When you look at the difference between the Opti and the MSD, you'll see the reason for the price difference. Installing is the same.
bill
Arkybill is offline   Reply With Quote
Old 04-19-2009, 03:29 AM   #14
curtis74
CF Senior Member
curtis74's Avatar
Thanks Andy. I may just have to do that. Being a devoted C3 guy for so many years, I just look at this '95 engine bay and scratch my head several times wondering what in the world was I thinking . These cars a so much more advanced than a C3, but I do love a challenge!
Old 04-19-2009, 07:43 PM   #15
RR40vette
CF Senior Member
RR40vette's Avatar
can first gereration be upgraded to the second generation, vented opti?
RR40vette is offline   Reply With Quote
Old 04-19-2009, 09:08 PM   #16
NEVRL8T
CF Senior Member
NEVRL8T's Avatar
I have an MSD on the shelf in the garage to install when the one on my car goes **** up.
NEVRL8T is offline   Reply With Quote
Old 04-19-2009, 11:22 PM   #17
jrzvette
CF Senior Member
jrzvette's Avatar
Quote:
It require's a new timing chain cover. Also, the dirve pin from the cam to the opti is different. There are some othere parts that need to be changed as well, but I'm not sure what they are. Do a search, the topic has been discussed before. I think there's also a write up in the tech section on how to vent a first gen opti. The after market optis (MSD, Dynaspark) are vented in both the first and second generations.
Also, while the opti is out it's a good time to check the water pump and replace it as well if it shows any signs of wear. You can change an opti without removing the wp, but you can't change the wp without removing the opti.
Finally, whether you replace the wp or not, it's a good idea to fit a drain tube to the weep hole to allow coolant to bypass the opti in case the waterpump does fail.
Old 04-21-2009, 03:20 PM   #18
GREENC493
Junior Member
The MSD opti for the 92-93 has a vented style cap.
GREENC493 is offline   Reply With Quote
Old 04-21-2009, 04:27 PM   #19
BrianCunningham
CF Senior Member
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've got an MSD waiting in a box for my new engine.
I did a cap & rotor on my stocker when I hit 110k, it's got 140k on it now.
BrianCunningham is offline   Reply With Quote
Old 04-21-2009, 08:22 PM   #20
wheelsIII
Junior Member
I'm not sure how different the LT4 is - I have a 96 LT4 with 56K on the clock. The symptoms of a dying distributor in my case were an instantly dead engine on a back road...
I had it towed to the local dealer (I'm often on the road and I dont have time to work on it at all), and they told me that the water pump had a seepage issue which caused corrosion in both the distributer and (once they got it apart) the wiring harness. They recommended replacing the water pump as well as the damaged parts. They showed me the parts - and they were really frammissed.
FWIW
Tom
wheelsIII is offline   Reply With Quote
Reload this Page MSD or optispark
Tags
1996, ac, adjustment, box, c4, corvette, delco, difference, mds, msd, optispark, reinstall, sensor, timing, vented
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Havent found straight answer! What all to completely upgrade the optispark? A BirdMan Converted C4 Tech/Performance 30 06-01-2005 02:38 AM
[LT1] Can a hotter coil screw up the Optispark? Lone Ranger C4 Tech/Performance 13 11-10-2004 01:04 AM
LT1 Distributor / optispark problems, some useful links semvhu C4 Tech/Performance 10 05-01-2003 11:18 AM
msd 6a need help comp94 C4 Tech/Performance 11 03-26-2003 01:45 PM
High Performance Billet Optispark Dist>>>> DTE Powertrain C4 Tech/Performance 56 12-10-2002 12:12 AM
Cam Change? Or would I even notice the difference? Langadorf C3 Tech/Performance 15 07-26-2002 01:25 PM
MSD, another option instead of OptiSpark for LT1's XTwinTurbo C4 Tech/Performance 16 05-25-2002 01:26 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
