Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C4 Corvette Discussion not covered in Tech Sponsored by
Marc Heitz Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-05-2009, 06:07 PM   #1
slplank
CF Senior Member
Support Corvetteforum!
slplank's Avatar
Default Walk Me Through Removing the Battery
I have a 1990 Vert that will soon require a new battery. Taking a quick look under the hood I can see it will not be your typical remove / replace scenario. That baby is buried. Can anyone describe the best approach and any "gotchas" to look out for? I did a search but surprisingly did not turn up what I was looking for.
Thanks for any input.
slplank is offline   Reply With Quote
Old 03-05-2009, 06:28 PM   #2
Paul Workman
CF Senior Member
Paul Workman's Avatar
Default Very easy to remove battery...
The side panel comes off - screws on inside of fender, and loosen one on the bottom, access thru a slot between the frame and the panel - you'll see it when you get on your prayer bones. (No need to remove the bottom screw, just loosen it as the panel is slotted there to accomodate easy removal.) Slide the pannel toward you and a way from the battery. Nuttin toit!
P.
Paul Workman is offline   Reply With Quote
Old 03-05-2009, 06:29 PM   #3
RollaMo-LT4
CF Senior Member
St. Jude Donor '10-'11-'12-'13
RollaMo-LT4's Avatar
It's really pretty easy. The side panel comes off, and you slide the battery right out.
http://www.corvettemagazine.com/2001...ttery/bat1.asp
__________________
1996 Corvette - LT4
2011 Camaro SS Convertible
2011 Harley Davidson FLHX Street Glide
RollaMo-LT4 is offline   Reply With Quote
Old 03-05-2009, 06:32 PM   #4
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
Location: Fremont Ca. I will do No business with ANY company that boycotts Arizona.
Send a message via AIM to Z51JEFF
What ever you do do cheap out and leave the 10MM bolt at the bottom tightened and pull the fender panel out,you will break the panel and then youll be buying a new one.A thin 10MM wrench works best getting the bottom bolt lose.
Z51JEFF is offline   Reply With Quote
Old 03-05-2009, 06:35 PM   #5
tuxnharley
CF Senior Member
tuxnharley's Avatar
Default Just did it last month on my '92 convertible!
Well, it's not as easy as some, but can be done in about two hours or so with hand tools. The key is it doesn't come out upwards - it goes out sideways by removing the "fender" panel between the front of the door and the wheel well, underneath the bottom edge of the hood clam shell.
That in itself is a multi step process because some of the fasterners are either hard to get to, hidden under other body pieces, and./or require the special Torx head tools. It goes like this:
1. remove the first front 3 fasteners from the underside of the rocker panel trim piece so you can drop it down away from the bottom of the fender panel to get to a hidden bolt there.
2. remove the bolts from the top, bottom, and front of the fender panel. The front ones are Torx and require at least turning and maybe removing the front wheel to get at them. Remove the fender panel.
3. Remove the battery hold down bolt and then slide it out sideways thru where the fender panel was. BE CAREFUL NOT TO HIT THE BATTERY TERMINAL POSTS ON THE METAL BRACKET ABOVE IT THAT HOLDS THE CAR'S COMPUTER/CPU. You can fry the CPU if you do.
Reverse the process for installation.
Good Luck!
tuxnharley is offline   Reply With Quote
Old 03-05-2009, 06:49 PM   #6
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
Good Luck!
2 hours?15 minutes tops.This is not a difficult job,4 Torqs bolts at the front of the fender panel,if you dont have the Torqs bits you can get by with an Allen key set,2 10MM bolts,one on top one on the bottom between the fender and rocker panel,this one you have to look for but its not hidden.
Old 03-05-2009, 07:30 PM   #7
Vett4Ted
Junior Member
Vett4Ted's Avatar
Obvious ... But be sure to remove the negative cable 1st , and then the positive last. There is a metal bracket above the positive, and you do not want to risk a direct short with a wrench...
I may have to do my 92, in a few days also..
Good luck ..
Ted
Vett4Ted is offline   Reply With Quote
Old 03-05-2009, 08:34 PM   #8
tuxnharley
CF Senior Member
tuxnharley's Avatar
Default 15 minutes???????????
Quote:
Hey Jeff - I'll be happy to pay you shop rate for 15 minutes next time mine needs changing!!!!!! Maybe you're just a lot younger and fasster than I am! Or, maybe it was because I was talking about total time including taking the old battery to the store, buying a new one, and bringing it back to install it - as well as a beer break or two along the way!
Old 03-05-2009, 09:20 PM   #9
Z51JEFF
CF Senior Member
Z51JEFF's Avatar
Sure,I could use the money,Im in Fremont.I forgot one of the tools,13MM socket and 6 inch extension for the hold down clamp.
Old 03-05-2009, 09:34 PM   #10
deerra
CF Senior Member
deerra's Avatar
Quite frankly, it's a PIA to change. Same with the fuel filter. Nothing like engineering a car to make regular maintenance items difficult to service.
deerra is offline   Reply With Quote
Old 03-05-2009, 09:44 PM   #11
96polovette
CF Senior Member
96polovette's Avatar
Send a message via Yahoo to 96polovette
You will want a socket wrench with a long extension for the battery hold down bolt. And take off any metal watch or jewelry. Last time I was installing my battery I was trying to get the positive bolt screwed into the battery and my metal watchband touched the negative terminal while I was fooling with the positive and I got zapped!
96polovette is offline   Reply With Quote
Old 03-05-2009, 09:59 PM   #12
kenmack
CF Senior Member
kenmack's Avatar
Default coupla hints
Turn your wheels hard left and ignition lock them in position.
This allows access to the 3 torx head screws (2 diff sizes)in the fenderwell.(remove completely)If your new battery has plastic caps on the terminals,save them to put on your old battery for removal(no shorts).
I've done this a dozen times and never loosened the bottom screws. (If your slow and gentle) the panel flexes enough to remove old and install new battery.
Just one 1/4 " or 5/16"screw in door jam to remove.
P.S.When you put that screw back in the doorjam,ensure that the panel is aligned correctly,with the door (closed)and the hood (down)
20-30 min tops.
kenmack is offline   Reply With Quote
Old 03-05-2009, 10:23 PM   #13
ELVIS' C4
CF Senior Member
St. Jude Donor '09, '13
ELVIS' C4's Avatar
make sure you check the alignment by gently shutting door to make sure it doesn't scrape paint...take your time...still should take you no more than 15 min once you have done it once
enjoy!
ELVIS' C4 is offline   Reply With Quote
Old 03-05-2009, 11:32 PM   #14
Eakster
CF Senior Member
Eakster's Avatar
This one's a great introduction to C4 construction - fasteners all over the place and 3 different tools to get a panel off.. have fun
Eakster is offline   Reply With Quote
Old 03-06-2009, 01:25 AM   #15
jabez
CF Senior Member
jabez's Avatar
Send a message via ICQ to jabez Send a message via AIM to jabez
2 HOURS??
That must include an hour and half nap.
jabez is offline   Reply With Quote
Old 03-06-2009, 07:26 AM   #16
touringmike
CF Senior Member
touringmike's Avatar
Good Luck!
I take mine out thru the top. 15 minutes max.
Remove the cruise module, unbolt top of brace, swing brace over a few inches, tilt battery, comes out at about 15 degree angle.
touringmike is offline   Reply With Quote
Old 03-06-2009, 08:29 AM   #17
WW7
CF Senior Member
WW7's Avatar
This is what I had to do on my car also, I have a ground effects package and it goes over the panel so this was much faster,15 minites tops for the whole job..WW
WW7 is offline   Reply With Quote
Old 03-06-2009, 10:48 AM   #18
tuxnharley
CF Senior Member
tuxnharley's Avatar
Default Geez, what a tough crowd!!
Quote:
Originally Posted by jabez View Post
2 HOURS??
OK, maybe I'm slow, or you guys all wrench for a living or something - but I was trying to give the OP a reasonable guess as to how long it will take HIM the FIRST time he does this, what with switching tools, total project time including taking the old battery to the store to exchange for the new one in the middle of the process (tell me again how that alone takes only 15 minutes?), etc.
Tell you what - let's let the OP be the final say on how long it takes him once he's done - he can report back and see who's closer to reality.
Beer bet, anyone?
PS - the bottom bolt on my fender panel is absolutely covered up by the rocker panel, no way to get to that one without dropping the rocker panel first. Maybe yours is different, but that's how mine came from the factory - never been hit. Also, on my '92, it's not just the cruise control unit that would have to be moved to take the battery out upwards, it's that AND the CPU/computer. No way I can see to do that in "15/20 minutes". Maybe some of you guys have earlier C4s where the CPU was located inside the car.
Old 03-06-2009, 11:02 AM   #19
tuxnharley
CF Senior Member
tuxnharley's Avatar
Default Man, you must be REALLY hard on your battery!
Quote:
20-30 min tops.
Old 03-06-2009, 12:38 PM   #20
WW7
CF Senior Member
WW7's Avatar
[QUOTE=tuxnharley;1569189472]OK, maybe I'm slow, or you guys all wrench for a living or something - but I was trying to give the OP a reasonable guess as to how long it will take HIM the FIRST time he does this, what with switching tools, total project time including taking the old battery to the store to exchange for the new one in the middle of the process (tell me again how that alone takes only 15 minutes?), etc.
Beer bet, anyone?
QUOTE]
This is where the discrepancy lies, usually you only count the mechanics of the job, not the breaks, or travel time, or beer runs...:o,,WW
Reload this Page Walk Me Through Removing the Battery
Tags
1985, 1990, 92, battery, c4, caps, corvette, elvis, gatos, los, mechanics, named, removal, remove, removing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Removing Airbag - to get to horn buttons RedZR C4 Tech/Performance 10 06-07-2005 10:31 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
