New exhaust
Old 02-08-2009, 12:39 AM
tim32920
tim32920's Avatar
Default New exhaust
I am wondering what kind of gains or changes if any, will I see by eliminating the cats and just running straight pipes from the manifold to new turbo mufflers on my 92?
Old 02-08-2009, 12:57 AM
ride250s
ride250s's Avatar
I vote on keeping CATS... your engine was made to run with them, and you can get hi-flow cats these days under $100/cat. I have also heard that the cats in later C4's aren't as restrictive.
Old 02-08-2009, 03:26 AM
dfalliaux
dfalliaux's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'15
How is your area with emmisions testing? More and more municipalities are getting stricter and stricter on emmisions. I would look into the local codes before I ran straight throughs.
Looking for a seat of the pants giggle factor change up the gear ratios. If you don't care about your top end gas milage this may be the way to go.
Old 02-08-2009, 09:19 AM
tim32920
tim32920's Avatar
We don't have emissions laws or inspections in fl yet but who knows the laws here are like the weather so maybe ill keep the cats.
Old 02-08-2009, 09:55 AM
ThomasRetUSN
ThomasRetUSN's Avatar
I put new y-pipes w/o pre cats with free flow cat with Magnaflow cat back system. That ready opened up my stock L-98.
Old 02-08-2009, 10:29 AM
Joe C
Joe C's Avatar
- i opted for keeping cats on my 90. i did however go with magnaflow's front y-pipe with hi-flow pre-cats (nice unit - 2.5 inch, mandrel bends), and magnaflow's hi-flow main cat. i ended with corsa's cat back exhaust system. quality of magnaflow and corsa is top shelf!!! everything's in the basement - just waiting for some decent weather here in NE ohio...
Old 02-08-2009, 11:43 AM
harrisr
8th Gear
harrisr's Avatar
Default Keep the Cats?
I recently replaced the defective Cats on my 88 y-pipe. One cat had the inside break free and sounded terrilbe. Went to ecklers and purchased the Dyn- a- flow y-pipe without cats and it comes with a new main cat. Everything fit perfect. Using Flowmaster mufflers. A bit louder. More power. Better starting and better milage.If Flotida gets emmission laws I might have a problem but that is down the road and the vette is 20 years old so it may be "grandfathered"
Old 02-08-2009, 11:53 AM
willyszr1
willyszr1's Avatar
if you dont mind changing the whole exhaust .going to a true dual exhaust like a 92-96 will get you the biggest gains. the coek in your system is the 2 into one pipe . its not that hard a deal to change over . you could buy a later cat back system and put 2 high flow catsin there or just delete them . if you do and your car is basicly stk stay with the 21/2 in sytem or you will use low end tq
Old 02-08-2009, 06:03 PM
RedVette84
RedVette84's Avatar
Corsa sports.
To New exhaust
Quick Reply: New exhaust
