c4 93
Old 12-18-2008, 12:25 PM
crivieccio
2nd Gear
crivieccio's Avatar
Default c4 93
any one know how to reset oil change light
Old 12-18-2008, 01:00 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
From the Owner's manual:
1. Turn the key to the RUN position but don't start the engine
2. Press the ENG MET button on the trip monitor. Within 5 seconds press the ENG MET button again
3. Within 5 seconds of step 2 press and hold the GAUGES button on the Trip Monitor. The CHANGE OIL light will flash.
4. Hold GAUGES button until the CHANGE OIL light stops flashing and goes out. This should take about ten seconds. When the light goes out the monitor is reset. If it doesn't reset, turn the ignition to OFF and repeat the procedure.
If you don't have an owners manual you can download on from here:
http://www.corvetteactioncenter.com/...al-discussion/
Quick Reply: c4 93
