coolant bleed valves
Old 11-28-2008, 11:29 AM
papafrancisco
papafrancisco's Avatar
Default coolant bleed valves
Where are the bleeder valves located on a 96 LT1? How much 50/50 GREEN coolant do I use? Do I fill with the rest with distilled water? Can't seem to find them in my FSM.
Old 11-28-2008, 12:16 PM
etteroc27
etteroc27's Avatar
I believe the bleed is located in the same spot as my 95. On top of the thermostat housing, on top of the water pump. The directions on the antifreeze will tell you how much to put in to protect your engine, depending on the temp you want to be covered. I use distilled water to top of my tank. It seems to work for me.
Old 11-28-2008, 02:07 PM
pianoguy
pianoguy's Avatar
The knock sensors have to be removed from the sides of the block in order to drain it. If you are switching to green, make sure you have flushed every last drop of the orange coolant from the system. 50/50 should be a good mix - use distilled water. If memory serves me correctly, I think the system capacity is around 17 quarts. Make sure to torque the knock sensors properly when you reinstall them.
Old 11-28-2008, 03:19 PM
96polovette
96polovette's Avatar
You may want to check past threads, there have been people in the past who have gone from dex cool to the green stuff and ended up with coolant leaks everywhere. The consensus seems to be if it originally came with dex cool to continue using it and flush it regularly.
Old 11-28-2008, 04:41 PM
pianoguy
pianoguy's Avatar
I'm sticking with the orange, no problems here.
Old 11-28-2008, 04:54 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
50/50 is usually the recommended mixture. If you top it off with water, distilled or otherwise, you'll dilute the coolant to less than 50/50. I think Prestone sells a 50/50 mix, top it off with that.
To coolant bleed valves
Quick Reply: coolant bleed valves
