Abandoned But Loved
Abandoned But Loved
Hi guys, newbe here. Need help with my 91vette. Due to extended illness (better now), my vette has been idle for the past 3 years. What's the best way to get her tip top again? Can I do it myself, or where can I bring it. I live on the very eastern tip of Long Island.
Is gas tank flush and battery replacement enough?
Any help, much appreciated.
Joe
Joe
Glad your feeling better. I would start by doing all the fluids Gasoline, Coolant,Trans,Brake and PS Fluids. Disconnect the Fuel Line front and rear and blow some clean fuel through the lines till it comes out clear and replace the Fuel Filter. Replace the Trans Filter when you put new fluid in it. New Spark Plugs are a good idea. Charge up the Battery and give it a shot. Remember to get all the nasty gas out of the tank and fuel lines and fuel rails and clean the injectors. After it fires up then you can worry about the small stuff Air Filter cleaning out the Throttle Body maybe Plug Wires and Distributor Cap. Let us know how you make out and GOOD LUCK Bring that Vette back to life Pipe
First,glad you are backup to vette standards. Having one and be able to drive suxs. Three years is a long time and specific recommendations are difficult without knowing how it was preped or stored. As a minimum all fluids need to be changed, that's gas,oil,transmission,coolant, power steering and the brake system flushed. If It were mine I would do a complete tune up to include oil in the cylinders and turning the engine over my hand for multiple rotations before you try to start. Add a detailed inspection of the entire electrical system, mice as well as other little critters love insulation for breakfast. I am quite sure there will be several folks along any minute now with their own ideas. Though we may disagree on what needs to be done one thing we will agree on is these cars fare much better when driven. Good luck.
Location: Minnesota in the summer, Las Vegas in the winter
Joe
Joe
Received 5,010 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I especially agree with the squirts of oil into each cylinder.
My other advice would be don't get discouraged if there are some minor glitches. Each one you fix is one less to deal with in the future. It may punish you for the past three years but as you drive it and correct issues its disposition will improve. A driven Vette is a happy Vette! And a Vette driver back in the seat after 3 years is certainly a VERY happy driver!
Welcome back
My opinion would be:
Fuel drain and blow out the lines before you try to fire it up. Put some mystery oil in the cylinders with the plugs out and spin it over a few times with a fresh battery. Put the plugs in, check the oil, some fresh gas, and rock and roll.
3 years isn't really that long so I don't think that you would have to change out things like brake, tranny, and PS fluid unless it is suspect when you check it.
Flat spots.
If your Corvette hasn't moved in three years, you might need some new shoes before you do a lot of driving. Old tires sitting for years are going to feel like square blocks of wood.
