Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-21-2008, 03:12 PM   #1
LSUvetteguy
CF Senior Member
St. Jude Donor '10
LSUvetteguy's Avatar
Default Blower motor fuse location?
I'm looking for an inline blower motor fuse location for a 93. I've done a thread search but can't find anything for 93. The motor stays on even when the key is off. Help.
LSUvetteguy is offline   Reply With Quote
Old 10-21-2008, 03:17 PM   #2
xlr8nflorida
CF Senior Member
xlr8nflorida's Avatar
Quote:
The module is under our hood and you can just unplug it so you don't get a dead battery.
You could need a new module or a blower motor which is pretty cheap about $65 but I doubt it's the fuse.
I replaced a blower motor on my 92 and its the same problem you are having. I'd buy its from the partsladi on ebay - takes about 30 minutes to fix it.
The part looks similar to this one (but this is not a corvette part) Click the image to open in full size.
xlr8nflorida is offline   Reply With Quote
Old 10-21-2008, 03:45 PM   #3
SunCr
CF Senior Member
That's a picture of the Blower Motor and Squirrel Cage which on this Vette works - it just won't turn off. The Motor - assuming it's Electronic Air - gets it power from a Module bolted to the left side of the Evaporator Case and the Blower will run with the key off if that Module is shot or if the return circuit carrying actual blower voltage back to the Processor (Programmer) is open. That return circuit is protected by a 5 amp fuse usually labled pgmr so look in your owner's manual for location and make sure the fuse isn't open (and if it is you probably need a new a blower motor). If it's good, you need a new Blower Module - should be acdelco #15-71970 http://198.208.187.182/internet/Part...rtnbr=15-71970 - or NAPA has a stocking number. Until you get it fixed, just disconnect the blower motor and tape the harness connector so that nothing can touch ground and short something out.
SunCr is offline   Reply With Quote
Old 10-21-2008, 09:43 PM   #4
LSUvetteguy
CF Senior Member
St. Jude Donor '10
Thanks, any additional comments are appreciated.
Old 10-23-2008, 05:41 PM   #5
LSUvetteguy
CF Senior Member
St. Jude Donor '10
A new module did the trick, blower works fine again. Thanks.
Reload this Page Blower motor fuse location?
Tags
1571970, 1984, 2000, 85, 94, blover, blower, c4, corvette, fuse, location, lokation, moter, motor, stays
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
