Need advise on replacement seats...
Hi All,
I recently purchased a 96 LT1 and there are what I think are c5 seats installed in it. They look nice but sit too high. I have decided to bite the bullet and buy c4 seats. For 94-96 seats Eckler's requires you send them the frame and they recover it. I don't have the c4 frames, so my question to you guys is can I buy 93 seats and bolt them in? Will the power seat controls still work?
I found a set of perfect 96 seats on ebay, but for $100 or so more I can get brand new 93's shipped to me, so I'm hoping they fit in my car easily.
Thanks in advance for your advise!
Below is a pic of the seats that are in my car right now.
Hi All,
Mine seem to sit just a little bit higher now also because they are covering the factory skins and there is padding underneath.
Thanks so much for the reply and pics!
So, I probably do have c4 frames. Probably be better financially to get new seats and sell these instead of having these recovered again. The way they are now they are not very comfortable, they sit too high and you don't sit "in" them.
As for my original question, can anyone tell me if I can order '93 seats and bolt them right into my '96? Any effect on the power seat tracks/buttons?
Are yours leather? If so I'd like first chance on them if you decide to sell them. (assuming you do have C4 frames) I may be interested even if they're not leather.
Rementis,
As I look a bit closer, If those are C4 frames, the installer DID place them over the C4 seat backs. You may not be able to remove them without damage..I really didn't see that at first. To bad they don't sit well for you as they look good.
First question, do the console controls for the seats work? If the seats sit too high, try to remove the bottom cushion, and then remove the straps that support the cushion. This will lower the cushion when you sit on them, should solve your problem.
Randy
Randy
I would stay with what you have as I like the '94 and up seats better. But if you like the '93's, I'm sure they could be made to work. It just depends on how much time and money you want to put into them...
