Climate Control Problems
Old 09-14-2008, 06:52 PM
rvs
rvs's Avatar
Default Climate Control Problems
I have a 93 convert. that the climate control system will not adjust temp. colder after initial startup, it will increase temp. If I turnoff engine and restart the temp can be adjusted colder. Any ideas out there? Thanks for your help.
Old 09-15-2008, 11:56 PM
Jonathon1990vette
Jonathon1990vette's Avatar
Mine has been messing up also. iI can't adjust the air flow higher and lower. Sometimes radom it will actually let me adjust it but most of the time not. And that module thing is like two hundred something at ecklers.. So i would like to hear idea's also.
Old 09-16-2008, 12:15 AM
2012 coupe
Support Corvetteforum!
2012 coupe's Avatar
Take it out, clean all the contacts, put it back in. Will probially run great again, at least mine did. another thing you can try, pull the fuse, run the car for over 5 miles. Shut it off, put the fuse back in and drive more then 5 miles.
Old 09-16-2008, 03:04 AM
VinceC4
VinceC4's Avatar
I had almost the same problem, When I tried to adjust the climate control nothing would happen. It seemed to happen if I let the car sit for a week or so, or when it rained..I cleaned all the contacts and it has been perfect ever since.
Old 09-16-2008, 07:48 AM
Soon2Bcammed
Soon2Bcammed's Avatar
I also had the same problem, one day it was about 95* outside and i went to put the A/C on.. the heat turned on and everytime i hit the temp "lower" button.. the temp would get higher!!
I took it apart and cleaned the contacts with a few q-tips and rubbing alcohol. It has worked perfect ever since.
Old 12-27-2010, 11:31 PM
jgiuffre
2nd Gear
jgiuffre's Avatar
Default AC control module
Where is the AC control module located? I would like to try cleaning the contacts. My temperature won't change up or down.
John
Old 12-28-2010, 01:03 AM
larry93lt1
larry93lt1's Avatar
Location: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
I wish I had that problem. The '92 I got in August had a heater core leak the night I bought it on the way home. I put a bypass in until October, replaced the heater core, it was as much as a PIA as the '93 I sold the day before I got the '92 except a broken ground wire added to the excitement of the '92's.
My heat will work only if I set the heat at 85 or 90 anything below that and it's cold air. Not real enjoyable when it's 26 outside.
To Climate Control Problems
Quick Reply: Climate Control Problems
