moan in rear??
09-02-2008, 06:46 PM
moan in rear??
Just did a search and sounds like the answer is to change rear diff oil, is this true? Only happens when starting off in a turn. 93 6speed
09-03-2008, 12:18 AM
Are you sure its not just the ASB check groan?
09-03-2008, 02:13 AM
Remove mother-in-law from trunk area
or it might be the ABS thing
09-03-2008, 09:02 AM
positive its not ABS or mother-in-law
its on normal take-off turning
09-03-2008, 10:30 AM
My thoughts are either the posi clutches running dirty or dry, or the rear wheel bearings are toast.
Mike
