spark plugs
Old 06-28-2008, 11:44 PM
tankman
tankman's Avatar
Default spark plugs
Okay,I've got another shadetree question.Yes,I searched,and yes,I have the FSM,I just don't know how you guys/gals get that front spark plug out & back in on the passenger side of the '87.I guess it's # 2.I spent most of the afternoon changing plugs & I only got 7 changed.Do I have to jack the car up,remove a wheel,cuss less,or what?Thanks to all who respond.
tankman
Old 06-29-2008, 12:02 AM
Demonic85
Demonic85's Avatar
That would be the infamous cylinder #8 plug. The easiest way to get it is to use a flex head ratchet. I've also gotten it out by using a 5/8" open end wrench as well. Getting under the car will also make it easier.
Old 06-29-2008, 12:07 AM
tankman
tankman's Avatar
Thank you very much.I'll try again in the morning.
Old 06-29-2008, 12:21 AM
deerra
deerra's Avatar
I removed the tire, fender liners, (center and the rear). Made things a lot easier for all the plugs and its a no brainer on the liners.
Keep trying, it can be done.
Old 06-29-2008, 05:45 AM
UNCLEBILL
UNCLEBILL's Avatar
Old 06-29-2008, 07:15 AM
tankman
tankman's Avatar
I'm going to try to do it without removing all of those parts.It's the plug closest to the radiator on the passenger side.This is unbelievable ,I know I tried for about 3 hours last night and got no where,but I'm raring to go this morning .
Old 06-29-2008, 11:12 AM
John A. Marker
John A. Marker's Avatar
I just use a LONG 3/8" extension thru the fender well to get to this plug (#2). A 1/2" extension seems to be too thick to get thru the tube and other S**T in this area. I don't have to take off the tire. Try this first before you start removing parts.
On #8 (passanger side rear) I jack up the car to get under it. I use the plug socket with a piece of solid 1/2" square stock about 1" long into the socket and a 1/2" open end wrench.
-John
Old 06-29-2008, 12:10 PM
ALS 08
ALS 08's Avatar
Same here. Removed fender liner behind wheel and went through that opening behind upper ball joint. No need to take of wheel. May have even used a swivel on socket as well.
Old 06-29-2008, 12:26 PM
tankman
tankman's Avatar
Well,I'm still being hardheaded.I didn't have a major problem getting # 8 out,the problem was getting it back in.I may have to give up and start tearing stuff off because I don't see how I'm going to get it as it sits.
Old 06-29-2008, 03:31 PM
newbecorvetteguy
newbecorvetteguy's Avatar
Carefully. You don't want to bugger the first thread. I usually have good luck slipping a piece of rubber fuel line over the end of the spark plug and get it started by turning the hose. Gives it a gentle touch turning while allowing a little movement so it can line up. If it starts in crooked, the hose will spin on the spark plug keeping you from damaging the thread. I changed plugs on my '87 last year without any problems that I remember.
Good luck.
Old 06-29-2008, 03:42 PM
tankman
tankman's Avatar
Thanks to everyone for the responses ,I think I'm going to take a break from the #2 plug,because I'm inventing too many new cuss words .
Old 06-29-2008, 05:14 PM
denvervet
denvervet's Avatar
I came in thew the wheel well did not remove it used a swiveil and a couple long 3/8s ext and rachet
I do like the vacum hose idea thanks for that newbecorvetteguy
Old 06-29-2008, 05:45 PM
TA
TA's Avatar
I always found #2 pretty easy. As others have mentioned, a couple extensions and you go through the wheel well...........a couple minutes tops. As for #8 I've also had a little trouble in past getting the new plug started. The method that works for me is actually laying over the motor from the driver side. It puts your arm in a different posotion and makes it a snap. After changing plugs on my car many times I've got it to the point where it takes me no more than about 45 minutes to change all 8.
Old 06-29-2008, 06:25 PM
3D-Aircrew
Support Corvetteforum!
3D-Aircrew's Avatar
I had a lot of trouble getting 8 back in too. I'll try that trick next time... Thanks
Old 06-29-2008, 06:36 PM
tankman
tankman's Avatar
Finally got #2 out,hope it doesn't take as long to get the new one in.Thanks again to everyone who helped me.I'll definitely try the tubing.
Old 06-30-2008, 12:52 PM
tankman
tankman's Avatar
Whew! Finally got new #2 installed.I'm glad I won't be changing plugs on this 'vette again.It's very difficult for me to believe that some people can change plugs on an '87 quickly & without resorting to major profanity .Thanks again to all who helped me.
tankman
Old 06-30-2008, 12:56 PM
Relic
Relic's Avatar
#2 really, really sucks. What I did is use a spark plug socket that would accept a 3/4" socket on the end. I then got an articulating 3/8" drive, and a shorty 3/4" socket. Put the plug socket on the plug, fished the drive with the 3/4" socket down and got it on the back. That worked. Used fuel line to get the plugs started, and was careful not to over torque. Used anti-sieze as well.
Old 06-30-2008, 01:37 PM
tankman
tankman's Avatar
I also used a piece of fuel line as someone had suggested & don't think I could have replaced it otherwise.This was an experience that I don't want to repeat.Thanks for responding.
To spark plugs
Quick Reply: spark plugs
