Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-20-2008, 09:56 AM   #1
wayne k
Junior Member
Default INFL REST warning lamp reset
I just got my 90 out of the shop and now the infl rest light is on.It wasn't on when it went into the shop.I had injectors and ecm replaced.Mechanic swears it was on ....oh well.Can I turn this light out using the ALDL terminal?A grounding issue with this light was fixed 2 years ago.Did replacing the ecm have anything to do with this ?I'm starting to like this car more and more.
Thanks Wayne K
wayne k is offline   Reply With Quote
Old 06-20-2008, 07:39 PM   #2
frontier1111
CF Member
frontier1111's Avatar
I have a 1990 with the same problem. Airbag light along with set belt warning light. I bought my car that way. Chevy dealer tried to fix problem but, Only managed to turn the light off for a few days by reseting somthing. They say they can't find the sensor needed to make repair since it's only used in 1990 model and has been out of production. Only used parts can be found and all of them bad. If you get it fixed Let us know how... I've learned to live with the light, Its the only thing wrong with the car.
frontier1111 is offline   Reply With Quote
Old 06-20-2008, 11:23 PM   #3
90Indy
CF Senior Member
90Indy's Avatar
You guys are experiencing one of the most common issues with the 90. I had the light come on several years ago due to the right sensor and just a few months ago the light came on again this time because of the left sensor.
The problem is corrosion between the frame and the sensor. Mine was very easy to fix. I just disconnected the battery, removed the two bolts holding the sensor, sanded both the sensor/frame faying surfaces, coated them with dielectric grease and reinstalled the sensor.
To turn off the light I use a special plug/switch I bought from Corvette Central (I think) for a nominal cost but there are other ways to do it.
Just make sure you disconnect the battery before you mess around with the sensors. Good luck.
90Indy
90Indy is offline   Reply With Quote
Old 06-21-2008, 07:55 PM   #4
pipe
CF Senior Member
Send a message via AIM to pipe
Yep most of the time it's the right front frame sensor that goes bad. Sometimes you can repair the problem by DISCONNECTING THE BATTERY then removing the sensor and taking a dremel tool or small grinder and removing the paint or corrosion on the frame where the sensor sits and sanding the bottom of the sensor and applying some dielectric grease to both areas then I put small star washers on the bolts (better ground) and re fastened em. Then ya gotta clear the code to turn the light off. Mid America sells the connector/button tool that hooks to your ALDL connector under the dash that will remove the code Remember sometimes cleaning the frame and sensor won't always work and the sensor must be replaced. Pipe
pipe is offline   Reply With Quote
Old 06-22-2008, 07:41 AM   #5
tomtom72
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Support Corvetteforum!
tomtom72's Avatar
Just a fwiw on the InflRest + seat belt light. Most of the time it's not a part failure, but rather a loss of ground issue. The sensors are bolted to the frame rail and they use the bolts/mounting tabs as a ground. The fix is to remove the sensors and clean up the tab and frame area and apply some di-electric grease and use star washers on the remount.
Now to get rid of the code is the tough part. I tried several times and until I made a "tool" to do the grounding and un-grounding of the proper ALDL pins I had no luck. I found that the timming of the grounding & ungrounding was key.....my 90's FSM says 3 seconds on the grounding & ungrounding, +/- .5 sec. I bought a momentary switch and used phone wire as my leads because it fits into the ALDL sockets. Then I used my watch to do the timming. I was jazzed when my light went out.
Check the mounting points for crud and then try the switch thing. Ofcourse, if you have a TECH1A, clearing the DTC from memory is a snap.
Tom
tomtom72 is offline   Reply With Quote
Old 06-22-2008, 09:33 AM   #6
Wildride
CF Senior Member
Cruise-In II Veteran
Wildride's Avatar
This is a good write up on servicing the inflatRest light.
http://www.corvetteforum.com/techtip...D=46&TopicID=2
Wildride is online now   Reply With Quote
Old 06-22-2008, 12:18 PM   #7
myscx
CF Senior Member
myscx's Avatar
I just fixed mine. The tech explanation on the forum is not very detailed. First you should find out what the codes are. I used Gordon Killebrews grounding plugs which work great. If you find out which code, it will probaly be a bad ground. There is GM bulletin describing the problem and fix. You must with the battery disconnected remove the sensors (little black boxes with a bolt front and back) from the front frame rails. Sand both the sensor and the frame rail clean and apply di-eletric grease to the bottom of the sensor and reinstall. I would suggest you do both sensors at the same time. This basically only applys to the 90 cars since GM put dieletric grease on the 91s and up. Getting to the sensors requires a little bit of work. On the drivers side you need to remove the fender, battery, inner wheel well cover and battery tray. On the passenger side remove the fender, inner wheel well cover and windshield washer fluid bottle. The passenger side is the harder one to get to. After you reassemble everything, hook up the battery and reset the codes. To do this I used the grounding plug for the airbag and plugged it in to the ALDL with the car off. Then I turned the car on(not starting), waited for the airbag light to start blinking.As soon as it does remove the plug and count 1001,1002,1003 and plug back in and then unplug and count 1001,1002,1003 and plug in.I did this about 3 or 4 times. Then turn off ignition, unplug ground plug and start car. The airbag light should come on for a few seconds and then go out. If not then try the reset procedure again. The tech procedure on the forum tells you how to reset with a wire which will do the same thing. Or you can use the switch one from Mid America or where ever and reset it with that. I personally like Gordons ground plugs cause they are simple and you can use them whenever you have any other fault lights come on. Hope this helps. It took myself and a friend about two hours to do this, with less info than what I'm writing here.
__________________
1990 Dark Red Metallic coupe ,L98, Auto, performance axle 3.07 gears,every option, minor mods: ,Accel supercoil,Accel 8.8mm plug wires, Accel cap and rotor, Bosch platnium +4 plugs,Diehard Gold battery, Bosch O2 Sensor,180* thermostat, Hypertech chip, Targa style SS mufflers, Sylvania Silver Stars, 885 fogs,50 watt backup bulbs, Mobil 1 oil and filter,Mobil 1 ATF, Dexcool coolant, Frisbee Free, K&N air filter, Cut lid,Power Now TB airfoil,Earl's SS Braided brake hoses, 140AMP Alternator, R&D Cross Frame, DRM Brake Bias Spring, R&D Cross Brace,Firestone Firehawks,Transgo shift kit,Rear Diff drain plug kit with Mobil 1 75w90,Timing 8*btdc,Protected by V1
myscx is offline   Reply With Quote
Old 06-22-2008, 12:22 PM   #8
pipe
CF Senior Member
When I grounded the pins in the ALDL Connector I had a trouble code #26 which is the right front frame sensor fault so no matter how much I would have cleaned the corrosion and sensor it would still have the INFL REST light on no matter what I did. The sensors have Ohm specs and the connector is down in the footwell area of the driver & passenger compartment. Pipe
Old 06-22-2008, 12:42 PM   #9
Allentown Ernie
CF Senior Member
Default Code #26
Yeah, I just did mine as well, It was a P.I.T.A. to get at the right sensor however it is doable. The problem becomes obvious cause the only ground is the mounting bolts. Getting rid of the codes is tricky doing the 3 second counting thingy. But I did follow the F.S.M. and I did succeed. Just sand the frame and sensor, put on the grease and feel good about fixing it yourself. Remember, the tech at the stealership has probably never done this repair as well. Think about paying them $90 bucks or so an hour to learn how to fix your Vette. By the way it is a good thing to learn how to read the codes by grounding the correct pin to the seat frame. As a old Mack Truck retiree it gives me great pleasure to fix a problem myself and keep the money in my pocket, Happy Corvette motoring. Allentown Ernie.
Allentown Ernie is offline   Reply With Quote
Old 06-22-2008, 12:51 PM   #10
myscx
CF Senior Member
myscx's Avatar
Quote:
According to Gordon Killebrew, "If fault codes 15,16,25 or 26 are set, refer to GM bulletin 90-436-9J. There may be corrosion between the right or left uniframe impact sensors and the uniframe." So if you clean the sensors and the frame like I suggest and reset the light you should have no more problems. Of course there is a possibilty it could be a bad sensor, but more than likely it will be a bad ground(the sensor to the frame). If all else fails Gordon is only a phone call away.........
__________________
Old 06-23-2008, 06:41 PM   #11
pipe
CF Senior Member
Peel back the carpet in the footwell area an OHM them then you'll know for sure. Pipe
Old 06-24-2008, 04:58 PM   #12
myscx
CF Senior Member
myscx's Avatar
I wouldn't put an ohm meter on those sensors unless you want your airbag to go off. The easy fix is to clean the sensors, put the di-electric grease to them and reset the light. Trust me this is the most common problem with the 1990 airbag system
__________________
Old 06-24-2008, 11:25 PM   #13
pipe
CF Senior Member
If the battery is disconnected it wont happen cause your not testing the connector that goes to the DERM your testing the pigtail to the frame sensor Pipe
Old 06-25-2008, 03:35 PM   #14
myscx
CF Senior Member
myscx's Avatar
Goodluck
__________________
Old 06-25-2008, 07:13 PM   #15
wayne k
Junior Member
You are absolutely right .The timing sequence is important."K" terminal to "A" and follow the instructions .It helps if you run 2 wires from the aldl terminal long enough that you can sit in cars seat with watch on dash,makes the timing seq. MUCH EASIER.Car fixed.
Thanks Wayne K
Old 06-25-2008, 08:04 PM   #16
Wildride
CF Senior Member
Wildride's Avatar
Glad to be of some help.
After many years on this forum (almost the beginning) I have seen what seems to be just about every problem imaginable posted again and again and usually a solution. Unfortunately, the answers
often have been buried in the archives and the archives seem to have been lost through program "updates" etc. This one was still there!
Since I noticed the trend for the archives to go "missing", I have made copies of the "good stuff" and keep them in a loose leaf binder for future reference. They have come in handy!
Good luck with your 1990. (I have had mine for 17 years).
Old 03-18-2009, 07:41 PM   #17
flatbush862
CF Senior Member
Default Inflatible ( airbag) / seatbelt light
Where is this sensor physically located in the car??? I have this problem as well on my '90
flatbush862 is offline   Reply With Quote
Old 07-23-2012, 10:46 PM   #18
CDVBMX304
Last Gear Tapped
CDVBMX304's Avatar
Colton Murrin MoToSTAR_CM304
Send a message via MSN to CDVBMX304
I have this light on, been on forever, I hate it and I hate the service ride control light, I know what needs to be done. Always an adventure/pita fixing stuff on this car... But man does it make a guy happy to do it himself and save cash. Found this image via google images on the forums here. What a great tool google images.
CDVBMX304 is offline   Reply With Quote
Old 07-25-2012, 08:22 AM   #19
Allentown Ernie
CF Senior Member
Quote:
Thanks Wayne K
Yes, this is the way I did it. I ran one wire to ground and another wire to the proper terminal on the plug. I sat in the drivers seat and touched the wires together at the proper time. I followed the factory manual instructions and the wife called out the seconds to me. The sensor is on the right frame rail and a little tough to get at but doable. Sand sensor put on dialectic grease and the damn lite goes out after doing the reprograming thing. Mine has worked properly for years after this fix.
Old 07-25-2012, 08:39 AM   #20
summerst
CF Senior Member
summerst's Avatar
When all else fails, pull the bulb. I understand that the air bag is still functional when the light is on so it matters little if the bulb is in the socket or not. Sure beats black tape.
summerst is offline   Reply With Quote
Reload this Page INFL REST warning lamp reset
Tags
1990, aldl, battery, codes, corvette, diehard, find, fix, impact, infl, inflt, light, model, reset, rest, sensor, warning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
INFL REST light blinking... GKK C4 General Discussion 2 07-25-2013 10:36 AM
INFL REST light blinking... GKK C4 Tech/Performance 0 07-24-2013 07:40 PM
Door Locks & Infl Rest Light ken93vette C4 Tech/Performance 2 07-12-2013 04:14 AM
Infl Rest Light ken93vette C4 Tech/Performance 2 07-11-2013 01:14 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
