Starting Problems
Starting Problems
My 1994 Vette has always started at the turn of the key. But yesterday I got into it and tried to start it and it would not start immediately. When I did get it started it acted like the engine was flooded and running in 7 cylnders but it wouldn't hold an idle. I could smell a lot of fuel. Is this an airflow problem and how can I check to see if it is the air intake flow body.
Supporting Vendor
then check the fuel pressure in the rail after shutdown. Do the ohm check first and post the results.
I had a similar problem with my 91, it turned out to be the fuel pressure regulator , which went bad it was hard starting,cause it was flooded, and also smelled gas., went away for a few days and came back there was about 3 gallons of gas on garage floor.
I don't know your name, but if I could shake your hand I would. You are an asset to this forum and I am so glad you were patient enough to help a guy like me who didn't know much about the mechanics of his Vette. I hope everyone gets the chance to read this and takes your advice seriously. I learned a lot from you and you diagnosed my problem correctly right from the get-go. It turned out to be the fuel pressure regulator that was causing all my problems. It took me all but 15 minutes to change it out and the car runs fabulous. I hope you are still around the next time I have another proble. Thanks so much!!!!!
