How to make the brake line bubble flare?
Old 06-08-2008, 07:59 PM
John S 1961
John S 1961's Avatar
Default How to make the brake line bubble flare?
how do I remake the bubble flare at the proprotioning valve so I can cut off and replace a seriously corodded fitting at the brake prop valve which is leaking badly?
Old 06-08-2008, 08:07 PM
jcb5565
jcb5565's Avatar
Do you have a double flair tool? If you do it a two step process, first flair it like a normal flair then put the double flair insert in and double it back on to its self. Its not hard, try it on a scrap pipe first for practice.
Old 06-08-2008, 09:05 PM
Livin the Dream
Livin the Dream's Avatar
I also have put the clamp into a vise to hold it shut . This has given me a better double flair -keeps the line from moving . The 2nd flair takes a little more pressure . but is is not hard at all
Old 06-08-2008, 10:42 PM
VetteSlave
VetteSlave's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Here ya go. Cheap too
http://www.harborfreight.com/cpi/cta...emnumber=40878
Old 06-08-2008, 11:54 PM
86PACER
86PACER's Avatar
With a double flaring tool.
If there is enough slack on your line, you might get away with just cutting right below the existing flare, sliding the old fitting off, new fitting on, then re flaring the end and ending up with enough line to re attach. If not, you need to splice in an extension to reach.
Either way no need to buy a tool you'll probably just use once. Go to Autozone and rent their double flaring tool. Part# for SAE version is 27015. Part number for Metric version is 27012. The instructions are right on the box. The diameter of your line will determine which kit you need.
If you need a tube bender, they have two available for rent also.
Part#27134
and
Part#27013
You leave a $25 deposit and get it back when you return the tool. So basically it's free as long as you don't break it or loose parts.
I used their flaring tool recently to make perfect flared ends on my trans line. I had a leak and cut the bad section out and spliced in a new section.
Napa carries straight sections of brake line with fitting already attached for dirt cheap (less than $5.00). They also carry the fittings by themselves depending on which way you're doing it. You should not be spending more than $10 for this repair.
I used a small pipe cutter to cut the line like this one:
Old 06-09-2008, 04:25 AM
skip5015
skip5015's Avatar
What You need is an ISO flaring tool. I was lucky enough to have a friend who had one and let Me borrow it. Not sure where You can rent one. Another idea is to go to Napa and buy a repair line with the ISO or bubble flare and replace the whole line. This is what I would recomend since the line could be weak in other places. Good luck. Skip
Old 06-09-2008, 12:03 PM
John S 1961
Default ISO bubble
thanks, I knew it wasnt an inverted double flare, now I know the real description!
Old 06-09-2008, 03:27 PM
86PACER
86PACER's Avatar
Your poor description did not help any either.
Old 06-09-2008, 10:43 PM
MK 82
MK 82's Avatar
Now don't we feel better!
Old 06-10-2008, 06:36 AM
Road Agent
Road Agent's Avatar
Old 06-10-2008, 06:39 AM
Road Agent
Road Agent's Avatar
Are the lines metric or inch?
Old 06-10-2008, 07:01 PM
texas 85
2nd Gear
texas 85's Avatar
If its ISO its metric
To How to make the brake line bubble flare?
Quick Reply: How to make the brake line bubble flare?
