Pic of door panel fix
Old 04-16-2009, 12:08 PM
  #41
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Originally Posted by corvettedan22
Mine werent that bad I just 2 part epoxied them. If they ever get that bad this is what I will do thanks !
I think I'll try the two-part epoxy or Gorilla Glue this weekend with a series of bungee cords connected to hold the panel ribs tight while the glue cures. I'll post the results later.
Old 04-16-2009, 12:59 PM
  #42
383tpimachine
383tpimachine's Avatar
I just put some extra HEAVY duty screws in the top
not an issue since lol
but yours looks stronger and better
may try on my passenger door
Old 04-16-2009, 07:58 PM
  #43
rs/ss 67
rs/ss 67's Avatar
I epoxied small metal plates to the top of my door frame last night then installed screws down thru the weatherstrip into the plates and all is well and I know it will stay forever. I beleive this is the best and easiest fix to date the I have read on the forumn.
Hope this helps some people out
Old 04-19-2009, 11:21 AM
  #44
mikey531
mikey531's Avatar
I just fixed mine ! Thanks !!!!!
Old 05-20-2009, 10:08 AM
  #45
jgclark
jgclark's Avatar
Default I finally fixed mine
I used aluminum plates, rivets and 2 part epoxy. That should hold it for a very long time.
Here’s pics.
Thanks for sharing this idea with us.
Old 06-24-2009, 09:29 AM
  #46
thomaskh
thomaskh's Avatar
GM designed this, owners fixed it. What's new Any questions
Old 06-24-2009, 06:20 PM
  #47
scrotocles
Support Corvetteforum!
scrotocles's Avatar
Default can someone spoon feed me please
where the hell do you guys get these materials ie, the rivets, the thing that turns what appears to be a nail into a rivet, the pattern to make the rib etc.
Can you get more elementary for someone who doesn't know beans?
Thanks.
This is a wonderful fix but I would love more info.
I can't make words until I learn the alphabet. Know what I mean?
Old 06-24-2009, 09:14 PM
  #48
BigTexas
BigTexas's Avatar
hey jgclark, can i buy some of those brackets from you for the ribs? for both sides? i dont have a clue or would want to make those. they are a work of art. please.
Old 06-25-2009, 11:22 AM
  #49
scrotocles
scrotocles's Avatar
Default ditto
ditto
Old 07-31-2009, 09:25 PM
  #50
BigTexas
BigTexas's Avatar
hello? I still want a set please! I have cash!!!
Old 08-01-2009, 10:43 AM
  #51
mfi
mfi's Avatar
You need to do an infomercial on this...too bad Billy Mays is gone as he would be perfect for this!!!
Old 08-02-2009, 03:13 PM
  #52
basselope
basselope's Avatar
Excellent! Thx for sharing!
Just my opinion, but I think jgclark put the finishing touches on this; gussets on both sides of the ribs.
Rivets have a tendency to sometimes cause "spidering" in plastics (cracks that radiate out from the hole.) By putting gussets on both sides you are much less likely to see future failures.
For those of you attempting this at home, I would recommend using aluminum rivets with aluminum mandrels (nails) so you don't put too much squeeze on that plastic.
Old 08-02-2009, 04:47 PM
  #53
kimmer
kimmer's Avatar
C4 of the Year Finalist
allright! dont have to buy anymore super glue
Old 08-02-2009, 05:13 PM
  #54
Heckler45
Heckler45's Avatar
I'm definately gonna have to do this.
-Dave
Old 08-03-2009, 11:40 PM
  #55
BigTexas
BigTexas's Avatar
I am gonna keep bumpin this until someone PMs me with some of those metal brackets to sell. So...............
Old 08-04-2009, 12:52 PM
  #56
scrotocles
scrotocles's Avatar
Default well
If you get a PM with the particulars, PM me so that I can get a set too
Old 08-04-2009, 01:44 PM
  #57
onedef92
onedef92's Avatar
I don't know about you guys, but my '92 does NOT have ribs at the top of the door panel like that.
To Pic of door panel fix
Old 08-04-2009, 03:33 PM
  #58
ch@0s
ch@0s's Avatar
It's a great idea i think you can do it
1.make a template out of cardboard
2.trace it onto aluminum
3.cut out with jig saw
4.drill holes in pairs so they match
5.rivet together
Good luck
Old 08-05-2009, 01:47 AM
  #59
BigTexas
BigTexas's Avatar
Sounds easy enough, but I suck at fabrication. Hmmm. I still wanna just buy a set. But thanks for the information. Surely one of these guys will be willin to hook a vette brother up!!
Old 08-05-2009, 06:15 PM
  #60
BigTexas
BigTexas's Avatar
to the top bump
Quick Reply: Pic of door panel fix
