vacuum manifold or AC/Heat Programmer for 88 Corvette
Old 04-28-2008, 06:51 PM
SpeedyKev42
SpeedyKev42's Avatar
Default vacuum manifold or AC/Heat Programmer for 88 Corvette
I am having a problem with my 88 Vette. When I press the Econ mode on the Auto Temp Control Unit it will blow out cool air. However, when I drive for a while, hot air will start coming out the vent. And, when I press the auto, heater, bi-level, and defroster buttons, the AC will kick in. The AC will not run when I press the Econ button. I think that the AC/Heat programmer or vacuum manifold has a vacuum leak or is bad. Only problem... I do not know where it is located on my car. Can someone tell me where it is located in a 88 Corvette?
Old 04-28-2008, 08:21 PM
pkazsr
pkazsr's Avatar
Cruise-In X Veteran
St. Jude Donor '09
Electronic Temp Control? If so, I'll post the flow diagram. In ECON outside air is passed inside without heating or cooling. So you will get engine heat when driving slowly and fresh air at highway speeds.
Old 04-28-2008, 08:28 PM
C4boy
C4boy's Avatar
In Economy mode, the compressor isn't supposed to kick in. That's where the economy comes from
Old 04-28-2008, 08:33 PM
89 Bob L
89 Bob L's Avatar
The programmer is located under the driver's side dash near the brake pedal. It is black in color and approx 3x6". You will have to remove the under dash pad to get to it.
Old 04-28-2008, 08:49 PM
SpeedyKev42
pkazsr... it is electronic auto temp control.. I would definetly appreciate if you can post a flow diagram .. thanks
Old 04-28-2008, 08:52 PM
SpeedyKev42
thanks... 89BobL... I will look underneath the hush panel tomorrow and near the brake pedal
Old 04-29-2008, 08:40 AM
AGENT 86
AGENT 86's Avatar
http://members.shaw.ca/dankai/AC%20Electronic.pdf
To vacuum manifold or AC/Heat Programmer for 88 Corvette
Quick Reply: vacuum manifold or AC/Heat Programmer for 88 Corvette
