Black Hose Clamps
1 Post
Black Hose Clamps
Does anyone know who sells black 'screw-type' hose clamps? I'm redoing the cooling hoses and would like to get better ones than the compression style that came stock. I started with regular chrome ones, but I would like black better.
If you can't find them just spray them with some high temp. I can't see waiting for special order clamps but that is just me.
Worst case is a little dab of touch up if you get goofy with the screwdriver
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
In any case, you are wise not to re-use the O.E.M. constant tension hose clamps.
I've known them to break over time. Not real common, but I have seen this happen. Use screw clamps and you'll be fine.
And don't reuse the original hose because the new clamp may not seal the old hose. I've seen hoses leak just from moving the constant tension clamp to a different position.
I went through this last year when replacing all of my hoses, it's the same advice that was given to me and looking back, it was excellent advice.
94flavette,
Good luck with your project and I hope you find your clamps. I put the chrome looking, screw type on my car and I really don't care for the look either.
cc
I also gave up on the black clamps. I did find a high quality stainless hose clamp that does not tear up the hoses, stays round and most of all does not leak under pressure. I believe they are ABA brand. High quality and holds all the goofy hoses put on the vette by GM. Search the net, you can find them everywhere at race suppliers- thats what they use. And they look nice
94flavette,
cc
