Torque Converter and Trans Rebuild Kit. Pics
I just got these today. Anyone know anything about transmission parts that wants to identify or comment? The rebuild kit is supposed to handle up to 675hp. http://www.700r4l60e.com/
Vigilante 9.5" 2800 stall TC
TransGo Shift Kit
TransGo Shift Kit
Looks like it'll really be built -- well, as much as you can build the 700R4/4L60 up. I know I priced out some of those parts last year and was blown away with some of the costs.
Oh, and cute converter.
"Complete description of the parts in the rebuild kit"
"Front pump"
Seal retainer
Late design seal
10-vane rotor with vanes, slide, rotor guide & pin assembly
Trans-Go steel rings & priming spring (over 5,500 rpm)
New replacement stator support
.500 boost valve
"Clutches, Steels And Pressure Plates"
4 Borg-Warner reverse/input clutches .078
4 Reverse/input "low drag" Turbulator steels .078
1 Reverse waved steel (eliminates the belleville spring that tears up the inside of the drum)
5 Borg-Warner forward clutches .070
5 Forward steels .090
2 Borg-Warner overrun clutches .078
2 Overrun steels .091
5 Borg-Warner low/reverse clutches .087
5 Low/reverse "low drag" Turbulator steels .068
9 Borg-Warner Hi-Energy 3-4 clutches .065
3 3-4 steels Kolene .060
5 3-4 Steels Kolene .076
2 3-4 pressure plates .128
1 3-4 apply ring 5-tabs
1 3-4 snap ring .062
Your choice of the input sprag below
Borg Warner dual cage 29 element design
or the Raybestos SKF single cage 29 element design
"Other" (these are additional parts that come in this kit)
Sealed Power Beast sunshell
Borg-Warner low/reverse roller assembly (late design)
Vamac 3 lip rear seal (prelubed)
Transtech paper & rubber (gasket) kit
Transmission filter (OEM)
Bushings (latest updates, including Teflon front pump & extension)
Thrust washer kit
Sealing ring kit
HD Bearing kit (Timken)
Borg-Warner Hi-Energy 2-4 band
Trans-Go Performance Shift kit w/accumulation for nice part throttle shifts
New steel molded rubber pistons for 3-4
New aluminum 2nd, 4th & forward accumulator pistons
New oem 4th accumulator pin
New 2nd & forward "hardened" (RC52) accumulator pins
HD steel sleeve, overrun piston, & steel molded rubber forward piston for the input drum
