Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-19-2008, 04:25 PM   #1
kylebuck89
CF Senior Member
St. Jude Donor '09
kylebuck89's Avatar
Default Armchair raceing GTO 6.0 Vs LT4
My best friend is going to go get a 2005 GTO A4, and we have been doing some arm chair raceing. I was wanting the forums opinon how the race would go in a closed track.
1996 Corvette Lt4
VS
2005 GTO Ls2
kylebuck89 is offline   Reply With Quote
Old 02-19-2008, 05:04 PM   #2
Demonic85
CF Senior Member
Demonic85's Avatar
LT4 for the win. IMO it will be a driver's race.
Demonic85 is offline   Reply With Quote
Old 02-19-2008, 05:09 PM   #3
beanieson
CF Member
beanieson's Avatar
Quote:
beanieson is offline   Reply With Quote
Old 02-19-2008, 05:42 PM   #4
rickneworleansla
CF Senior Member
rickneworleansla's Avatar
Send a message via AIM to rickneworleansla
Have you seen the new speed channel show Pass Time? I watched it for the first time last night. Not too bad.
http://www.speedtv.com/programs/pass-time/
__________________
95-Lt1-auto-Polo-Conv, 125hp ZEX N2O dry, LE Cam 226/234 565/565 109LSA, Comp Pro Mag 1.6rr, Patriot Xtreme Springs, PCMFORLESS tune, K&N, AO Ram Air, 52mm TB, EM LT Headers, No Muffler, X-pipe, Meziere HD EWP, Vigil 2800 Conv, TransGo Shift Kit, Pro-Built 4L60E Trans., 24lb SVO's, MSD Coil & 8.5mm wires, NGK TR6 plugs, B&M TransCooler, Dewitt Radiator, 160 therm, TB AirFoil, 3.07 Rear Axle, LT4 KM, S&D Rotors, SS BrakeLines, Hawk HPS Pads, ZR1 rims 275/315. 1967-Firebird-conv-2spd-326ci
rickneworleansla is offline   Reply With Quote
Old 02-19-2008, 07:26 PM   #5
gslotman
CF Senior Member
gslotman's Avatar
Power to weight ratio is where this one's going......
GTO weighs about 800+ lbs more and has 400 CHP
LT4 weighs 800-900 lbs less but has 330 CHP
Drivers race - probably, but my money's on the LT4
....let's hear from the LT4 CF members
gslotman is offline   Reply With Quote
Old 02-19-2008, 07:46 PM   #6
Aurora40
CF Senior Member
Aurora40's Avatar
The weight difference is not that bad. A GTO is listed at 3,725 lbs. The '96 C4 coupe is 3,300 lbs. That's a 425 lbs difference, not 8-900.
Power to weight:
GTO = 9.3 lbs/hp
LT4 = 10 lbs/hp
Aurora40 is offline   Reply With Quote
Old 02-19-2008, 07:50 PM   #7
kylebuck89
CF Senior Member
St. Jude Donor '09
kylebuck89's Avatar
yeah that is true if the LT4 is only puting out 330 but my lt4 puts 293 to the wheels. so maybe put it at 350 hp insted of 330
Old 02-19-2008, 07:56 PM   #8
Aurora40
CF Senior Member
Aurora40's Avatar
Quote:
http://www.calculator.com/
if you don't own one...
Old 02-19-2008, 08:01 PM   #9
kylebuck89
CF Senior Member
St. Jude Donor '09
kylebuck89's Avatar
HAHA what the calculator for?
Old 02-19-2008, 08:07 PM   #10
Aurora40
CF Senior Member
Aurora40's Avatar
If you want to punch up 3,300 / 350 instead.
Old 02-19-2008, 08:12 PM   #11
kylebuck89
CF Senior Member
St. Jude Donor '09
kylebuck89's Avatar
AHH i c says the blind man
Old 02-19-2008, 08:37 PM   #12
TOO_HOTTVETTE
CF Senior Member
TOO_HOTTVETTE's Avatar
I have an LT4 top end on my '93 six speed....Pretty sure I'd take him...Shhhhhhhh we don't have to tell him it's a stroked 383...Looks stock when you pop the hood....
TOO_HOTTVETTE is offline   Reply With Quote
Old 02-19-2008, 08:44 PM   #13
ps374
CF Senior Member
Heres the numbers I came up with
04 .. GTO..0to60..5.3....Quater Mile..13.6
96.. Corvette LT4 0 to 60...4.9 Quater Mile..13.4
ps374 is offline   Reply With Quote
Old 02-19-2008, 09:03 PM   #14
rklessdriver
CF Senior Member
rklessdriver's Avatar
Let's not forget the horrid wheel hop the GTO has to contend with. I have whipped quite a few LS1 and LS2 GTOs with my mostly stock 92 6spd LT1. Either they (good drivers) bogg it to keep the rear end from comming apart or spin so badly (the ones that don't care) that either way I have 2-3 cars by the 60ft marker. They can never make the difference up.
BTW around Jacksonville and Kinston NC, stock or mostly stock LS1 GTO's are in the 14.30-13.9 range. LS2's are in the 14.0-13.50 depending on driver. Some modified ones with good tires are much faster.
Since I moved to the DC area 3yrs ago I haven't seen any GTO's at the race track here.
I have drive quite a few over the years. Bottom line - IMO very nice cars, a bit overweight, with a lot of power and crappy suspension.
Will
rklessdriver is offline   Reply With Quote
Old 02-19-2008, 09:36 PM   #15
Razor89
CF Senior Member
Razor89's Avatar
The 06 GTO that I raced against at the track back in 06 ran a 13.08 and I just barely beat him with a 13.13
I was suprised that I was able to hang with him all the way down the track and I had to hit the brakes hard not to breakout before he did. We were both dialed in at 13.1
We talked later that day and when he saw that he got beat by a 19 year old tpi car his jaw just dropped. He also said his best time was a 12.9~
Razor89 is offline   Reply With Quote
Old 02-19-2008, 10:09 PM   #16
Mojave
CF Senior Member
Mojave's Avatar
If the GTO driver can get it to hook, it's going to be very close. If you think an LT4 puts out '350' but an LS2 only makes '400', you are fooling yourself.
I say it comes down to driver/tires.
Mojave is offline   Reply With Quote
Old 02-19-2008, 10:41 PM   #17
383_Proof
CF Senior Member
383_Proof's Avatar
383_Proof is offline   Reply With Quote
Old 02-19-2008, 10:59 PM   #18
bobmic93
CF Senior Member
bobmic93's Avatar
The GTO cant get out of the hole! LT4 wins hands down.
bobmic93 is offline   Reply With Quote
Old 02-20-2008, 12:58 AM   #19
Demonic85
CF Senior Member
Demonic85's Avatar
I've never raced a GTO, but have raced a C5. It was very close, but of course an '85 is no match.
Old 02-20-2008, 08:23 PM   #20
El T1
CF Senior Member
El T1's Avatar
Just do it!
IMO: Un-modded cars rated within a couple of tenths in the quarter come down to driver. Also, we don't know the mods involved...
Of slight relevance: I raced a GTO 6.0 M6 in my Trailblazer SS from 80mph. He spanked the crap out of me... It was pretty funny. I'm thinking there were a couple of mods on that particular goat...
El T1 is offline   Reply With Quote
Reload this Page Armchair raceing GTO 6.0 Vs LT4
Tags
corvette, gto, ls2, lt4, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
