Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-18-2008, 05:13 PM   #1
Bud90
Junior Member
Default Hand / Parking / Emergency Brake (how to adjust?)
How do you adjust a hand brake in a 90 C4? I took the caliper and rotor off and there is NO adjusting nut, I looked on the hand brake mechanism and I dont see a way to adjust it from there, I looked at the cables and these's NO adusting nut???? have searched???
Bud90 is offline   Reply With Quote
Old 02-18-2008, 05:42 PM   #2
staugur
CF Senior Member
staugur's Avatar
Automatic adjustment built into the parking brake lever.Pull out the drivers seat squab and remove the screws from the brake cover and you will see the mechanism in there.
__________________
'87 383 Lingenfelter
staugur is offline   Reply With Quote
Old 02-18-2008, 05:48 PM   #3
Bud90
Junior Member
Quote:
So how is it automatic? There's no adjusting nut? What do I do after I get the cover off???
thanks
Old 02-18-2008, 07:22 PM   #4
Bud90
Junior Member
anyone...
Old 02-18-2008, 10:42 PM   #5
Red Dwarf
CF Senior Member
Red Dwarf's Avatar
Quote:
Originally Posted by Bud90 View Post
anyone...
For 95 the adjustment is to pull up on the P/brake handle 3 times firmly.
More if it needs it. I can't remember if the procedure is the same for 90.
I can't even remember if my 90 had dics on all corners? I'm pretty sure it did. That's what happens when you get old.
Give it a try & see what happens. As Staugur suggested a little lube in the mechanism would probably help.
Red Dwarf is offline   Reply With Quote
Old 02-18-2008, 10:49 PM   #6
Bud90
Junior Member
I tried pulling it up firmly a number of times, nothing changed. Yes I have disks all 4 corners.
Old 02-18-2008, 11:04 PM   #7
Swift_Striker
CF Senior Member
Swift_Striker's Avatar
Send a message via AIM to Swift_Striker Send a message via MSN to Swift_Striker
don't know about the 90 but in my '86 I took the wheels off and rotated the disc to a certain spot (used haynes manual to find it) then there's a hole you stick a flathead screwdriver in and there's a star wheel you push either up or down depending on the side of the car you're doing
Swift_Striker is offline   Reply With Quote
Old 02-19-2008, 06:30 AM   #8
Bluewasp
CF Senior Member
NoVa Events Coordinator
St. Jude Donor '14
Bluewasp's Avatar
Send a message via AIM to Bluewasp Send a message via Yahoo to Bluewasp
How old are the rear pads and rotors?
Bluewasp is offline   Reply With Quote
Old 02-19-2008, 11:35 AM   #9
Bud90
Junior Member
yeah, maybe its the rear pads... Looks like there is no adjustment.
Old 02-19-2008, 12:08 PM   #10
jhammons01
CF Senior Member
jhammons01's Avatar
Don't the older ones have a small pad inside the RR Rotor that is used for the E-brake?
Correct me if I am wrong, but I just did my rear Brake Pads. The cable for the E-Brake went inside the RR Rotor, I just assumed it was the style where the E-Brake was like an old Drum brake using the inside of the Hub.
This would be consistent with Swift_Strikers post about turning a Star wheel with a Screw Driver.
jhammons01 is offline   Reply With Quote
Old 02-21-2008, 05:49 PM   #11
Bud90
Junior Member
Well, just to let everyone know. There is NO adjustment for the parking brake. My rear claipers were bad, so I had the calipers changed and now the e-brake works great.
Reload this Page Hand / Parking / Emergency Brake (how to adjust?)
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
