94 door outside trim removal
Received 6,929 Likes
2015 C2 of Year Finalist
how does it come off. I see one nut on each end of the door. how many more is there. or is it glued or does it have double sided tape?
A 10mm nut on each end, and then pop in clips all down the door. Get a long thin screwdriver or similar, and go down the strip carefully and pop them out one at a time. Get in a hurry and you risk breaking the molding.
the molding is already broken. I am just thinking how hard it would be to replace it. thanks for the help
