Too much "wheel" time?
Old 02-17-2008, 09:33 PM
stick105
stick105's Avatar
Default Too much "wheel" time?
I might get criticized as being a little too picky but I matched up the logos on my front wheels to be the same as my rear wheels. You know so the 5 star wheels and logos match front to rear on the same sides. Anyway I went for a 15 mile ride today and when I got home and parked my car the wheels are all mis-matched again. I know I have the same size wheels and tires on the car. Why does this happen? It will drive me nuts (not a long ride...atleast 15 miles).
Old 02-17-2008, 09:47 PM
PUNISHER VETTE
PUNISHER VETTE's Avatar
Um...
When turning one wheel turns less then the other. The inside wheel would spin less then the outside since the outside wheel has to travel a farther distance on the turn.
Also if you peel out a lot like me i know your rear wheels can spin independently of each other.
better luck next time.
Old 02-17-2008, 10:07 PM
ZfidyONE-84
ZfidyONE-84's Avatar
ok, your being a little too picky.... sorry had to be said
Old 02-17-2008, 10:08 PM
PUNISHER VETTE
Same thing with merry-go-rounds. The outside seats/animals travel much farther/faster since the circumference of the circle is larger for them and therefore go faster to make the same turn in the same amount of time the inside seats do.
your outside tires travel much farther in the turn and therefore get out of sink with the inside ones.
Old 02-17-2008, 10:36 PM
vetterlatethannever
vetterlatethannever's Avatar
Just drive the route in reverse now
Old 02-17-2008, 10:43 PM
StealthLT4
StealthLT4's Avatar
Here's what I do; just position the center caps the same relative to the valve stem. Then, they will be the same for each wheel, relative to that wheel. If you're **** and at a show or something, you can just jack up a corner real quick and rotate that wheel to get them all identical.
Old 02-17-2008, 10:48 PM
PUNISHER VETTE
I'm pretty sure some Bentley and Roles Royce cars have centercaps that stay level to the ground even when moving so they can be read at all times.
Old 02-17-2008, 10:51 PM
PUNISHER VETTE
"No-Turn-Technology" the phantom center caps remain up right while the wheel is turning
Old 02-17-2008, 10:53 PM
PUNISHER VETTE
here you go. Just pick up a set of these wheels and you won't have your problem anymore.
Old 02-17-2008, 11:02 PM
usaviator
usaviator's Avatar
Default Huh?
My son is a doctor, a clinical psychologist. I think I can get you a discount.
Old 02-17-2008, 11:05 PM
5POINT7
5POINT7's Avatar
Old 02-18-2008, 07:41 AM
mikeb
mikeb's Avatar
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Best Thread Of The Year.
Old 02-18-2008, 08:05 AM
TA
TA's Avatar
I'm hoping your joking
Old 02-18-2008, 08:20 AM
stick105
stick105's Avatar
If it weren't for me, you people would have nothing to smile about!!!
Old 02-18-2008, 09:05 AM
PUNISHER VETTE
or laugh at
Old 02-18-2008, 09:13 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
This one went downhill quick.
Old 02-18-2008, 09:18 AM
PUNISHER VETTE
At least i gave him the benefit of a doubt at first and explained it to him........
To Too much "wheel" time?
Old 02-18-2008, 12:19 PM
All2kool
All2kool's Avatar
This is a joke thread right? They would have stayed the same if you drove it in a straight line only. Can you say 'differential'?
Old 02-18-2008, 12:50 PM
cv67
cv67's Avatar
St. Jude Donor '05
Might be neck and neck with "Central Coaster tried to kill me!"
Cant find it...Apparently CC was kidding around and told some guy his car would stop better with his braking system filled half and half with water and brake fluid.
The guy actually did it and took 'er for a spin
ill never forget that one.
Old 02-18-2008, 01:23 PM
WW7
WW7's Avatar
Man, if this bothers you owning a corvette period is going to make you a real nut case with all the crap that goes wrong with these cars. WW
Quick Reply: Too much "wheel" time?
