cheap place for new weatherstriping?
This probably wont be the answer youre looking for, but when it comes to weather stripping, go with GM. Its not the "cheap" choice by far, however it fits like its supposed to. I have used other "top brands" in the aftermarket and always had fitment problems. Sometimes the length is incorrect, sometimes the locator pins dont line up with the holes in the body, sometimes once installed, the window or door is very difficult to close etc. When I used the GM originals, everything went smoothly.
Good Luck
Good Luck
good advice 81 !
i was thinking about the same cause im thinking replacing it all
weatherstripping its expensive as far as i have been looking for prices
hmmm where can we find good GM WS for our C4's ?
Good Luck
Good Luck
www.corvette-rubber.com
They make a lot of weatherstripping for GM. Used it in the past on my 93. Had great results.
Please be aware that "cheap" and "good weatherstripping" do not belong in the same sentence. Once you replace the rubber material, you will find out that it is not as easy as it first apprears. I am one of those who has to learn things the hard way......and now I only buy GM weatherstripping. Don't buy it retail from a dealer. Instead, there are web sites that will give you a discount on GM parts. Superior Chevy also gives good discounts to forum members.
