1984-1987 post your wheels pic
Old 12-02-2007, 08:04 PM
HIM666
HIM666's Avatar
Default 1984-1987 post your wheels pic
post you pic then tell us the brand, the width, bolt pattern, tire, backspace.. do you use spacer?
all the info about your wheel
im looking for cool wheels for next summer!
Old 12-02-2007, 08:13 PM
HIM666
HIM666's Avatar
do all those wheel fits my 95 vette?
http://search.ebay.ca/search/search....&fsop=1&fsoo=1
ive use 5x120.7 for keywords
Old 12-02-2007, 09:22 PM
c4cruiser
c4cruiser's Avatar
The bolt pattern spacing is actually 5x120.6 so it woudl be hard to tell if your search term will fit exactly. For example, BMW wheels are 5x120 and they do not fit the bolt pattern correctly. A .1mm difference "may" be OK but the wheel should be installed on the hub to make sure.
The correct wheel offset for your car is 56mm. The backspacing will change somewhat depending on the width of the rim but for a 9.5" wide wheel, backspacing will be about 7 1/2".
Also, many aftermarket wheels may not clear the Corvette brake caliper even though the wheel dimensions are correct. If you are going to use the stock tires, the front wheels will need to be between 8 and 9 inches wide and the rear wheels should be 9 to 10 inches wide.
If you are going with a larger diameter like 18's or 19's, you need to make sure that the overall tire diameter is close to that of the stock tires. Too big a diameter and you throw off the speedo.
Old 12-02-2007, 09:51 PM
All2kool
All2kool's Avatar
Direct fit 17" (9.5) Chrome ZR-1's from FactoryReproductions.com via an eBay auction. Nice embossed Center Caps, not a crappy decal.
Tires are 275/40/17.
Old 12-02-2007, 11:43 PM
JonnyAngle
JonnyAngle's Avatar
17 x 9.5 all the way around. www.lakeshorewheelandtire.com and click on the "corvette specials" tab. $1400 rims and tires mounted, balanced, and shipped.
Old 12-03-2007, 12:57 AM
80sRule
80sRule's Avatar
I love my wheels, but if they ever go bad, I'm thinking the black chrome variant of JonnyAngle's wheels. They look good...
My wheels:
AFS Black Chrome ZR1 wheels. 17x9.5 up front w/ 275/40ZR17s and 17x11 in back w/ 315/35ZR17s.
Old 12-03-2007, 12:58 AM
corvettedan22
corvettedan22's Avatar
c6 wheels with adapters
18s
and
19s
My c6 rims
http://forums.corvetteforum.com/show....php?t=1667787
Old 12-03-2007, 07:41 AM
mikeb
mikeb's Avatar
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
'85 Turbines.
Old 12-03-2007, 07:57 AM
schrade
schrade's Avatar
Originally Posted by touringmike
'85 Turbines.
Are those 16's? Like from an '86 or so?
I've thought of puttin' my '94 sawblades on my '98 GMC Jimmy... I got no rubber on the rims now. The fronts are the 8.5's, and the rears are 9.5's.
Did you have to the adapter thing for your Blazer?
Old 12-03-2007, 08:37 AM
Muffin
Support Corvetteforum!
Muffin's Avatar
From TomZ.18X10.5 in back with one inch adapters and 17X9.5 in front direct mounted.
Well that sux, can't see the wheels. Try this.
Old 12-03-2007, 04:28 PM
pmihaltian
Slingshot
pmihaltian's Avatar
Default 10" Bbs
10" BBS with OEM Gatorbacks
Old 12-03-2007, 07:49 PM
flyzlow
flyzlow's Avatar
Old 12-03-2007, 09:06 PM
FireLieutenantPhilly
FireLieutenantPhilly's Avatar
nice...................................p ics
Old 12-03-2007, 09:25 PM
HIM666
HIM666's Avatar
keep these pic and info rolling
Old 12-03-2007, 09:27 PM
HIM666
HIM666's Avatar
so are these wheel fits better? using as key: 5x120.6
Old 12-03-2007, 09:44 PM
lil_Mike
lil_Mike's Avatar
i got some c5 thin spokes painted black with 1" spacers on the rear(might need them on the front too).
Old 12-03-2007, 09:57 PM
mikeb
mikeb's Avatar
Turbines off my '85, 255 16s.
No adaptors; bolt pattern the same, offsets???
I had to knock the center caps out on the fronts for the hubs to fit through.
Tire rub in sharp turns.
I only did it for fun, took them off the same day (It looks silly, lowered the truck an inch)
To 1984-1987 post your wheels pic
Old 12-03-2007, 10:58 PM
tdonlin
tdonlin's Avatar
Here's one more. 84 with the 17" Y2K thin spokes. I did need the adapters. Didn't know squat when I bought these and went with a 245 instead of the stock of 255 and kind of regret not having the bigger meats on the rear. If I did it again, would go with a black chrome wheel and bigger rear tires. I'll get around to lowering the rear one of these days.
Old 12-04-2007, 12:42 AM
xrcrx
xrcrx's Avatar
Old 12-04-2007, 12:47 AM
corvettedan22
RPD, You definately need that spacer for the front , it is sitting in way to far and does not loook right.
Get that done and it will look good, like the rims, different.
Quick Reply: 1984-1987 post your wheels pic
