Replacing the turn signal switch
Old 08-07-2007, 01:00 AM
James in MD
James in MD's Avatar
Default Replacing the turn signal switch
This evening I tried to activate the turn signal for a right turn and the signal stalk just kind of flopped and no right turn signal. The left worked OK at first. A little later I signaled a left turn. The signal worked but now the lever is flopping in both directions. High beams and washer functions still work. Do I replace the ring and connector arrangement that is offered by Ecklers and others as a replacement turn signal switch, or do I have to replace the turn signal lever as well? TIA!
Old 08-07-2007, 03:58 AM
The Green Hornet
The Green Hornet's Avatar
Location: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Just did mine and it's a major PITA. I'll bet it's not the switch. What happens is a raised piece on the WIPER switch that activates the turn signal switch breaks off and the stalk wont activate right turn, left turn works but won't cancel manually. Sound familar?? The fix is pull the airbag modual, steering wheel, airbag coil, lockplate and canceling ring, pull the turn signal switch as far as you can after removing the metal wishbone piece attached to it. pull the ignition cylinder key switch, then the upper housing cover and then you can remove the broken wiper/ pivot switch. Ecklers has the best price on the switch you need. Good Luck to you.
Gunho (06-23-2020)
Old 08-07-2007, 11:27 AM
91vetteboy
91vetteboy's Avatar
Old 08-07-2007, 12:30 PM
James in MD
Green Hornet, thanks! Your description is exactly what I experienced. I'll be ordering the wiper switch in a few minutes. Based on your description of the work involved I haven't decided if I will do the work or have it done.
mpodell (07-31-2022)
Old 08-07-2007, 12:34 PM
ARMAN72
ARMAN72's Avatar
mine is the same way ...whats the part number?
Old 08-07-2007, 04:14 PM
The Green Hornet
Ecklers item # for 90-93 wiper switch is 37478
Old 08-07-2007, 05:15 PM
The Green Hornet
If you have a Factory Service Manual, you can tackle this job. If you have any questions along the way just pm me and i'll help you any way i can, heck, if you were closer i'd come over and do it for you. I learned a few tricks about getting everything back together after doing mine.
Let me know how things work out for you.
Old 08-07-2007, 05:19 PM
5POINT7
5POINT7's Avatar
sounds like a lot of work for a turn signal. Best of luck!!!! Let us know how it goes. I agree with with green hornet, grab an FSM if u dont already have one, makes every job 100 times easier.
Old 08-13-2007, 09:50 PM
James in MD
Sorry it took so long to reply I've been away from the computer for few days. I ordered the part from Corvette Central (they had it in stock), and the car is going to the shop in the AM. I will invest in the manual soon but based on the description of the work involved, and demands on my time I decided to follow the path of least resistance and pay to have the work done. I'll post an update when the work is done.
Old 09-06-2019, 03:37 PM
Lori Braiker
5th Gear
Lori Braiker's Avatar
Default Wiper/pivot switch
Green Hornet, this is exactly why had just happened to my 1992 Corvette. I can't find the part you are suggesting anywhere. Do you have a part number?
Old 09-06-2019, 07:48 PM
Hot Rod Roy
Hot Rod Roy's Avatar
Lori, welcome to the Forum. You have responded to a post that is 12 years old, so you probably won't get the answer you're looking for. We call that a "Zombie" thread. Please start a new thread.
Old 09-07-2019, 07:08 AM
The Green Hornet
Here is some info. on that switch.
https://www.rockauto.com/en/catalog/...er+switch,4856
Old 09-07-2019, 07:13 AM
The Green Hornet
It;s the bottom 2 that are out of stock, maybe Ecklers or Corvette Central would have one. check their site with the part numbers.
Old 09-09-2019, 11:59 AM
Lori Braiker
5th Gear
Originally Posted by The Green Hornet
Thank you for your help
Old 09-09-2019, 01:09 PM
pushrod-v8
pushrod-v8's Avatar
Your best option is to look on eBay.
I just purchased one from eBay a couple of months ago.
Old 09-09-2019, 02:16 PM
Lori Braiker
5th Gear
Nice, I'll do that
Old 03-31-2020, 06:21 AM
jklumpp
jklumpp's Avatar
Hi All - I know this is a 13yo thread, but this exact thing has happened to me!
I parked the car, thinking 'I'll worry about that later'..... but seeing as my rego is now due, I think I better start worrying about it - especially considering I'm in Australia, and I'll have to try & ship parts during this global pandemic!
So can anyone give me some updated info on what the actual parts are that I need, as I'd like to get the parts here so I can pull it all apart & fix it at the same time - rather than dismantle & then wait weeks for parts to arrive!
Is it this:
https://www.ecklerscorvette.com/corv...1989-1996.html
And seeing this is a common problem, does anyone know of a step by step or video showing what to do?
I think I'll need to get a FWSM.....
To Replacing the turn signal switch
Old 03-31-2020, 04:01 PM
ls777z
ls777z's Avatar
Pandemic or not it's always best to get the parts before you tear your car apart. Nothing worse than tearing it apart, rendering car inoperable, and the part you need is no longer available, and you can't even find a used one. Even worse, you break something else during dis-assembly that you now need to find. Yes, I have an 1984....
Old 03-31-2020, 05:55 PM
jklumpp
jklumpp's Avatar
Which is OK provided you KNOW what part you need...... Hence my question! :-D
Old 03-31-2020, 08:55 PM
CA1992C4
CA1992C4's Avatar
The turn signal lever on our 1992 broke and after looking for days on the internet I finally had to buy a complete steering column out of a wrecked 1992 C4 and had it shipped to my home. I located the steering column at Dino’s Corvette Salvage - phone number - 1-601-818-8389.
After getting the steering column, it was easier to take it apart on the work bench to see how it came apart, and then how it went back together. Dino was a lot of help, and I would order parts from him again. It was more expensive to buy the entire steering column than just the part, but I couldn’t find just the part so I did what I had to do to get it fixed. A plus was I got a really nice almost new steering wheel with the column to replace my worn out one.
Good Luck!
Quick Reply: Replacing the turn signal switch
