A/C only blowing through defrost and floor
Old 05-31-2007, 04:10 PM
Chad072
Chad072's Avatar
Default A/C only blowing through defrost and floor
I don't come here that often, but this is THE best place for Vette information, so here goes...My a/c has stopped blowing from the vents and only blows through the defrost and the floor. Has anybody had this happen to them before? What could be the problem and how would I fix it? It blows cold, and gets annoying when driving at night when my windshield starts frosting over and I have to keep running my wipers.
Old 05-31-2007, 04:15 PM
Wheelman
Wheelman's Avatar
Sounds like one of your blend doors is not moving correctly. Do you have electronic or manual A/C?
Old 05-31-2007, 04:17 PM
Chad072
Chad072's Avatar
It is electronic. I'm not an auto expert, but I was wondering if there was some kind of door that directed the air.
Old 05-31-2007, 05:30 PM
-=Jeff=-
-=Jeff=-'s Avatar
What year??
Do you have the Factory manual?
The Manual has a nice troubleshooting section for this issue..
My guess is it will be a bad Programmer (under dash) or a vacuum leak causing the vents not to move
Old 05-31-2007, 05:41 PM
slicked25
slicked25's Avatar
Bad A/C Programmer and/or Blower Control Module.
Old 05-31-2007, 11:24 PM
Chad072
Chad072's Avatar
It's a '94. Thanks for the responses. I'll get the manual out and take a look at it this weekend. I want to get it solved before the endless 90* days start.
Old 06-01-2007, 12:01 AM
93*Corvette
93*Corvette's Avatar
Your 5 minute repair....
It's most likly this vacuum valve under the fuel rail.
Old 06-01-2007, 05:51 AM
enventr
enventr's Avatar
easy enough to check first
Old 06-01-2007, 09:20 AM
Goldcylon
Goldcylon's Avatar
Old 06-01-2007, 09:56 AM
Casethecorvetteman
Casethecorvetteman's Avatar
Check that vacuum valve first as shown by 93*Corvette, that is a common failure and WILL cause exactly what youre describing.
Old 06-01-2007, 11:30 AM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yup. That valve runs $5.12 online from GM Parts Direct.com.
NAPA carries it, too, according to C4 guru Gordon Killebrew.
To A/C only blowing through defrost and floor
Quick Reply: A/C only blowing through defrost and floor
