Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C4 Corvette Discussion not covered in Tech Sponsored by
Marc Heitz Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-28-2007, 01:30 PM   #1
tdellaringa
CF Senior Member
tdellaringa's Avatar
Send a message via AIM to tdellaringa
Default Loose door panels - how hard to fix?
One of the issues with my new vette is loose door panels. Apparently the previous owner had them off to replace weather stripping. (On the right side, it apparently was so bad it scratched the window).
Well whoever did it, did a horse-butt job of putting the panels back on. Here is what they currently look like:
Click the image to open in full size.
Obviously they rattle when you close them and the doors don't close firmly. I have no idea why they were left this way (other than laziness).
I also have a part that he bought (I have all kinds of bags of screws and such that he bought and never used) that supposedly helps the door/window not rattle - apparently they were never installed:
(Sorry for the bad pic, I put the text on the bag clearly)
So I'm wondering how much trouble it is to take these apart and fix them up right... and should I use these anti-rattle parts he has? It seems like the panel is not hooked on right. I have nothing to reference though, so I have no idea. Any tips are appreciated!
Tom
tdellaringa is offline   Reply With Quote
Old 05-28-2007, 01:37 PM   #2
CentralCoaster
CF Senior Member
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Looks like they're not even installed correctly.
Remove them and make sure they're hooked over the top of the door snugly before screwing them in.
Those pads just push the window towards the outside to keep it tight. They have nothing to do with the panel.
Metal "arm rest savers" will help secure the panel better.
CentralCoaster is offline   Reply With Quote
Old 05-28-2007, 02:07 PM   #3
tdellaringa
CF Senior Member
Quote:
Are these internal or external pieces? (I assume internal inside the door?) Is it a big job to take these off and put them back on?
Old 05-28-2007, 02:24 PM   #4
Mark C5
CF Senior Member
St. Jude Donor '08-'09-'10
Send a message via AIM to Mark C5
This is one of those "small" jobs where having the Helms manual really pays off. You don't have your profile filled out so I'm not sure what year your car is but judging by the end of the panels, it appears to be a '95 or '96. There is a lattice affixed to the inside of the panel that has 4 hooks on it that go into corresponding slots on the inside of the door. These lattices are made of plastic and will often be broken, so I'd check that first. If they are ok then you should be able to correctly install the panel with no trouble. Also, the factory decided to not install a screw in the ent of the panel on '95 and '96's for some reason. You can see the bracket where the screw goes in your picture, it's opposite the door latch. But the plastic inserts and drill the holes and they will help greatly. The "door savers" CC mentioned do not apply to '95 or '96's because the door panels are screwed directly into the door on these years unlike eariler cars. Best of luck and congrats on your new Vette.
Mark C5 is offline   Reply With Quote
Old 05-28-2007, 02:25 PM   #5
CentralCoaster
CF Senior Member
They go where the handle is, on top of the panel and secure it to the metal part of the door, so you're not pulling on the plastic panel when opening it. Not even sure if that applies to newer doors. Mine is an 85.
The panels tend to crack where they hook over the door. If yours are, you can either reinforce the panel, or put some brackets on the top of the door to hold what's left of the panel better.
Old 05-28-2007, 04:45 PM   #6
tdellaringa
CF Senior Member
Where's the best place to get a Helms -ebay? Are they year specific? My car is a 95'. Are there any parts I should make sure I have before I start this? I don't think my panels are cracked, they seem in fairly good condition, but I guess you never know til they are off.
Old 05-28-2007, 04:52 PM   #7
bldavis11
CF Senior Member
bldavis11's Avatar
Send a message via AIM to bldavis11
A Helms is the way to go for the detailed instructions. You just need a screwdriver and time. There is nothing special about this. You need to take off the door panel, and then reinstall it correctly. There is a lip on the top of the door panel that fits over a flange on the door sheet metal. You need the manual for the instructions on how to disassemble the door panel.
bldavis11 is offline   Reply With Quote
Old 05-28-2007, 05:06 PM   #8
Mark C5
CF Senior Member
Many people get a Helms off Ebay and save a good deal. I bought mine directly from Helms for about $125. The manual is a 2 book set, if you buy off Ebay make sure you are getting both volumes. Also, there are two versions, a white one which is a preliminary version and a red one. I would get the red one.
Old 05-28-2007, 07:56 PM   #9
ynk1121
CF Senior Member
ynk1121's Avatar
Send a message via AIM to ynk1121
the door panel hangs from the top and then screws hold the panel against the door. if all the screws are in place and the top keeps coming loose then its cracked ribs. once the ribs crack the panel can't hold its shape and it slips off the top lip of the door. it's very common on these cars. get your self some "J-B Weld" adhesive and give all the ribs of the door panel a generous coating then wrap the panel with masking tape tightly to keep its shape until it drys. did this fix a few years ago and it's still holding strong.
ynk1121 is offline   Reply With Quote
Old 05-28-2007, 09:00 PM   #10
CentralCoaster
CF Senior Member
I do not see the point in buying a Helm manual to reinstall a door panel.
Wiring diagrams / diagnostic info sure. But for basic assembly, no.
Old 05-28-2007, 10:40 PM   #11
Greg Gore
CF Senior Member
Greg Gore's Avatar
Cracked ribs, very common. Door panel spreads out and won't stay hooked on at the top. The other common problem is broken corners and cracked retainer holes at the bottom from prying it off the door and not being careful. Excellent fix advice above. When you have the door panels off for the repair job take the opportunity to examine the plastic window guides at bottom of glass toward the front. If half worn through they need to be replaced or will break soon and window will flop around in the door.
Greg Gore is offline   Reply With Quote
Old 05-29-2007, 12:59 AM   #12
95VetteMan1
CF Senior Member
Default Door Panel
Helms manuel is not that expensive...good to have
95VetteMan1 is offline   Reply With Quote
Old 05-29-2007, 07:28 AM   #13
tdellaringa
CF Senior Member
Quote:
Originally Posted by ynk1121 View Post
the door panel hangs from the top...did this fix a few years ago and it's still holding strong.
Thanks for the detailed info! I appreciate you writing that up.
Old 05-29-2007, 07:30 AM   #14
tdellaringa
CF Senior Member
That was going to be my next question. I do plan on getting one sometime, but I have shelled out a lot of cash recently. I imagine if I take note of everything as it comes off I would be okay...
Old 05-29-2007, 11:32 PM   #15
96polovette
CF Senior Member
96polovette's Avatar
Send a message via Yahoo to 96polovette
I just went through this last winter and found that all the ribs in my drivers door panel were cracked. If they're cracked they won't hold the top of the door panel on and it will keep slipping off. I had no trouble removing and reinstalling the panel and I'm not what you would call an expert at working on cars. At the time I didn't have the Helm manual but I do now and it is an excellent resource. I only had the Chilton repair guide which had adequate information about removal and reinstallation procedures for the panel. This can be purchased at your local auto parts store. I also installed an L bracket at the top of the door to hold the top of the panel on better. My repair and some more information is in the link below. Its still holding together strong. I hope this helps.
http://forums.corvetteforum.com/show...ght=door+panel
96polovette is offline   Reply With Quote
Old 05-30-2007, 08:07 AM   #16
tdellaringa
CF Senior Member
Thanks! That is helpful. I still don't quite get what the ribs are, but I guess when I get it off I will see. The L-brackets make sense. What did you use as a glue to reinforce them?
Old 05-30-2007, 02:06 PM   #17
Madmikeee
CF Senior Member
Cruise-In X Veteran
St. Jude Donor '06
Madmikeee's Avatar
Location: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Send a message via AIM to Madmikeee
Even the simplest jobs have caveats that having a manual around will help you to avoid. Plus if you have never done work like this before it's good to learn the CORRECT way to do it than to go diving in because someone who has done it a number of times told you it was simple and then you crack the ribs, strip out screws or 1000 other things that could go wrong.
Get the manual, do it right the first time. One of my favorite quotes:
"Why is there never time to do it right the first time but there is always time to do it over?."
Madmikeee is offline   Reply With Quote
Old 05-30-2007, 03:00 PM   #18
tdellaringa
CF Senior Member
Darnit, he has a point there.
Old 05-30-2007, 03:02 PM   #19
onedef92
CF Senior Member
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
onedef92's Avatar
Quote:
You can order them here.
http://www.factoryautomanuals.com/home.php
onedef92 is offline   Reply With Quote
Old 05-30-2007, 06:11 PM   #20
96polovette
CF Senior Member
You can use a construction adhesive you get at a hardware store. I used a product called Titebond Polyeurathane Liquid Glue. If you look closely at my pictures in the link above you will see the ribs on the underside of my door panel. I have a 96 so mine should be similar to yours. I put a metal bracket on each side of the rib over the crack and bolted them in place. If you look at the picture the repair should be self explanatory. The liquid glue I also used to hold everything in place. Glue alone probably won't do the trick as the ribs of the door panel flex alot and there is a lot of stress every time you yank the door to close it. The glue is the white squishy stuff you see in my picture.
When you remove the panels undo all the screws with red arrows in the diagram above and don't forget to pop out the interior door light. Take your time and remove the panel slowly, disconnecting the wires in the trunk release and window switches very carefully before removing the panel all the way.
When installing the L brackets you just undo the bolts on the top of the door and place the L bracket on them. The rear one has a window buffer in the door so be ready to catch it on the inside of the door or it will fall inside the door when you remove the bolt to place the L bracket on it. I used 1" metal corner brackets from the hardware store. You bend them about 10-15 degrees towards the interior of the car for a good fit.
You may not need to repair your ribs, you won't know what it needs until you remove the panels and look the inside over. Like you said it could have just been a half @ssed door panel reinstallation. Another option if you got the cash is to purchase new door panels online for about $500 apiece.
Reload this Page Loose door panels - how hard to fix?
Tags
c4, c5, corvette, door, fix, fixes, fixing, loose, panel, panels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 247 Today 11:39 AM
c5 coupes typically leaky? LSUgoTIGER C5 General 29 04-01-2012 06:43 AM
Newbie thinking of buying 1st C2 Corvette bertschb C1 & C2 Corvettes 36 03-10-2005 01:15 AM
What do you guys think a high mileage 86 c-4 with dealer intalled Alwyn678 C4 General Discussion 21 10-25-2003 07:08 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
