Magnaflow mufflers with longtubes on L98?
Hey,
Right now I have hooker longtubes, with true duals (with h-pipe) into 2 flowmaster 40's on my 89. I'am looking for louder (It's really not loud but does still sound good ) I am interested in these #324365
http://www.corvettecentralexhaust.com/c4perfmagna.htm#
I want just the mufflers with LT1 tips. Supposedly they are straight through so that has to make me louder, and I'am sure it would sound badass. I know louder is not always better, But I feel this set-up would be louder and prob sound even better? Does anyone have some sound clips PLEASE!!! Especially with longtubes and no cats.....I'd be your best friend
-Jared-
-Jared-
My understanding is thart the Magnaflows are a more "refined" sound than the Flowmasters. I have found that the Flowmasters sound like most of the P/U Trucks running around here in redneckland.
If you want loud... why don't you just do muffler eliminators?
A straight through... ( gives eliminators sound) muffler (no performance loss)
I just really want to hear this set-up before I buy the mufflers...ya know.
hmmmm, what do you have done. Mine has long tubes and no cats with the flowmasters. I would think that's as loud as I would get with them. It's just not loud enough for me. My buddies stock LT1 camaro with a SLP catback (stock manifold and cats) Is just as loud as mine. Doesn't sound nearly as good, but still just as loud. I love my car loud
if you want loud go with B&B I have a friend with a c5 and he put that catback system on. it just devours anything in site, godly idle sound, godly rev, godly take off. it sounds killer, but its like $800...
Irregardless...
Without knowing all of the specifics of someone else's combo, tune parameters, and racing/testing conditions, nobody can possibly say that their car will loose power with a specific muffler (or lack thereof) just because one other person's may have.
Not to mention, there are way too many variables (at the track) to narrow down a power loss to one specific part. Was the car in the exact state of tune? Was the temperature, humidity, barometric pressure and density altitude all exactly the same as when previously tested? Was the track temperature the same? Tires hooking exactly the same? etc...
There are no golden rules as far as every car or combo reacting the same exact way to a certain modification. What works for someone else, may not work for you, and vice-versa.
In a nutshell...If you do not try something on YOUR setup, you'll never know if it works or doesn't work.
Basically it boils down to:
Flowmaster mufflers are what they are.. high-flow mufflers that use multiple baffles to cancel noise. They do have a distinctive sound, but for the most part, if you don't have a long duration cam, they sound "hollow" and tinny. With a long duration cam, however, they sound killer. Among other drawbacks are after time, the baffles can come loose and rattle, the bodies rust (they aren't stainless), and you sound like every other Mustang or pickup truck out on the road.
Magnaflow mufflers are a "straight through" design, with steel accoustic packing, similar to the old Thrush mufflers of the '60's and '70's. The tone is more of a mellow rumble until you mash the pedal, when they have more of a roaring tone (sounds killer with an X-pipe). The "refined" adjective is very appropriate. They sound good with a stock camshaft or a more aggressive one. They don't rust, as they are constructed from stainless steel.
Muffler eliminators are simply empty exhaust tips (or the cheapo Monza type "resonated" tips) with elbows welded on. With the original cats in place, they're not as loud as you would think (at least with resonated tips).
As to loud systems....
The loudest C4 exhaust I ever built was for a client. I used Twister race mufflers that I normally sell to the drag racing crowd (VERY low restriction!). I though it too loud myself, but the guy just loved it. Different strokes....
Thanks for the info everyone.....
Racerx70cc,
I guess you do exhaust work. Will the magnaflow mufflers give me a louder sound, but still sound good? I know louder isn't always better. My car does have a ZZ4 cam and aluminum heads.
Also will I loose HP with the eliminators. They are cheaper than the magnaflow and I'am sure they would sound louder too. But I need to weigh out the advantages for each. Thanks
Racerx70cc,
I agree that there are so many variables (cam, pipe size, cats, not cats. etc..) I am running 3" flowmaster 40s with single tip out. I am running big cubes, a rather large cam and true duals with an X. At idle it sounds just mean. Full throttle is super loud but good. Resonance sux. I get many positive comments about the sound and look (understated).
Well, on the brightside, it only took you 12 years to let us all know...
FWIW, I agree that they sound horrible. Had them for a short time on my old C4 and it basically sounded like an old farm truck with a rusted out exhaust.
