Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-25-2006, 06:36 PM   #1
corvette1989bham
CF Senior Member
corvette1989bham's Avatar
Default 86 (maybe 85 and 87) owners .. identify this vacuum line and where does it go?
I am putting back together a basket case 86. It had no vacuum lines on it, everything was capped off. Now I am trying to put the car back to stock and think these lines are the egr solenoid and throttle body vacuum lines....maybe maybe not. If so where are they routed? Pictures would be GREAT!
Click the image to open in full size.
corvette1989bham is offline   Reply With Quote
Old 12-25-2006, 06:50 PM   #2
evmlarry
CF Senior Member
evmlarry's Avatar
Send a message via Yahoo to evmlarry
Those look kinda like the hoses that connect under the plennum on the passenger side to me.
evmlarry is offline   Reply With Quote
Old 12-25-2006, 07:12 PM   #3
RRT vette
CF Senior Member
RRT vette's Avatar
Yep, those connect to the right side of the rear of the plenum. Above the FPR.
Looks like you have your work cut out for you. I went through all this about 5 years ago on my 86E basketcase.
RRT vette is offline   Reply With Quote
Old 12-25-2006, 08:09 PM   #4
corvette1989bham
CF Senior Member
I thought it was just a short hose from the fuel pressure regulator to the plenum...if this goes on the plenum then I have my fuel pressure regulator wrong.
Old 12-25-2006, 08:13 PM   #5
corvette1989bham
CF Senior Member
and this comes up to behind the distributor. Looks like a hard plastic or metal line/hose ? I cant tell. its a 4+3 car...aslmost looks like a filler tube...anyone know? It has a connector on it like something should be there?
Old 12-25-2006, 08:48 PM   #6
JackDidley
CF Senior Member
JackDidley's Avatar
There is a hard plastic line that goes inside the car for heat, AC controls. That is probably what you have behind the distributor.
JackDidley is offline   Reply With Quote
Old 12-25-2006, 08:55 PM   #7
corvette1989bham
CF Senior Member
Quote:
that is the line I have connected to the plenum (for the ac)
still looking for what this one is.
THANKS!
Old 12-25-2006, 09:25 PM   #8
RRT vette
CF Senior Member
RRT vette's Avatar
I'm sorry, the first pic is of one of the FPR vac. The other is for the front vac on the right side of the plenum and the rear is for the HVAC.
There should also be a diagram similar to this on your radiator shroud. I believe this diagram is more of a 87-89. It shows two vac coming from the EECS to the TB but there is only one on my 86E. There is one vac port on the bottom of my TB and that goes to the EGR solenoid.
Old 12-26-2006, 01:44 AM   #9
dancoffman
Junior Member
It hooks to the plenum for the hvac
dancoffman is offline   Reply With Quote
Old 12-26-2006, 02:16 AM   #10
1985 Corvette
CF Senior Member
1985 Corvette's Avatar
Send a message via AIM to 1985 Corvette
would the hard plastic black line be the vent tube for the 4+3? That's the only thing that comes to mind at the moment.
1985 Corvette is offline   Reply With Quote
Old 12-26-2006, 07:57 AM   #11
corvette1989bham
CF Senior Member
its not the hvac..that is hooked up. I 'll check on the vent tube?
Old 12-26-2006, 05:03 PM   #12
corvette1989bham
CF Senior Member
well..I am getting closer. I know by the diagram where the vacuum lines from the egr solenoid and throttle body connect to (on an 86). I can seem to find an connector near the cannister?
Old 12-26-2006, 05:07 PM   #13
JackDidley
CF Senior Member
JackDidley's Avatar
PM me your email. In an hour I can have the batteries charged for my camera. I will go take a few pics of my 87 and send them.
Old 12-26-2006, 05:16 PM   #14
scorp508
CF Senior Member
scorp508's Avatar
Man, someone really hacked up your car it seems. How does it run? I would expect the idle kind of sucks as it looks like you've got vacuum leaks everywhere. I wish you like in resurrecting it. Keep posting questions!
scorp508 is offline   Reply With Quote
Old 12-26-2006, 05:36 PM   #15
corvette1989bham
CF Senior Member
Quote:
yeah, there was no vacuum system to speak of on the car....how does it run? I dont know... hopefully I can tell you in an hour or two :0
Old 12-26-2006, 10:30 PM   #16
corvette1989bham
CF Senior Member
SpankYellow was kind enough to send me some GREAT photos...thanks!
OK...here is the update. Got the engine back together ...pics coming tomorrow, cranked it up.....cough,cough,pop,bam. Uh.......maybe its out of time? I marked the distributor when I removed it, put it back the same place......???? no go.... out with the service manual..... check timing manually............. dangit! Pull cap,wires etc double check....ok. Get the wife out to the garage.....have her crank it while I have my finger over #1...... 180' out...how did that happen? oh well....set the timing, put everything back together....break a few wires....fix a few wires...... try it again.... veroooommm! Cranks right up..instantly. who hoo! Idle is a hunting....600 to 900 , but havent set tps,idle air rest, or even set the timing via a light yet. Then still have to double check all this vacuum ...emissions lines that have been giving me fits. I also need to find where the spark knock harness wire goes...its off and I didnt notice the spark sensor location right off...anymore I am on vaction this week, so I will post more tomorrow with pics and probably post some more questions about where does this go? thanks again for everyone help!
Old 12-29-2006, 03:24 AM   #17
RRT vette
CF Senior Member
RRT vette's Avatar
Glad to hear you got it running. Any more progress?
Old 01-01-2007, 02:54 PM   #18
corvette1989bham
CF Senior Member
latest update...not much more progress, working on moving into the new garage I have been building for a YEAR... I got the entire motor back ,sat the timing....ran very well... idle was surging from 600 to 1000 rpm . . . Smoothed out after it ran a while. I think I have the egr solenoid and the vac line from bottom of throttle body to the round coffee can instead of the round grapefruit cannister . . . I am going to verify again the vac cable routing . . My o2 wire and spark knock connector are broken . , . I am going to put it on a lift and try to repair the 02 wire before I start tracking idle problems...car stays in open loop till it gets an 02 read . . . Will be a few days but I plan on keeping this thread updated due to the great amount of help received and I personally like threads that go all the way to the ultimate resolution!!!!! See Ya!
Old 01-02-2007, 07:15 AM   #19
RRT vette
CF Senior Member
RRT vette's Avatar
Keep up the good work and keep us posted.
Reload this Page 86 (maybe 85 and 87) owners .. identify this vacuum line and where does it go?
Tags
1985, 87, c4, chevy, corvette, diagram, egr, hose, line, lines, picture, routing, soleniod, solenoid, vacume, vacuum
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
