Help, Auxiliary Fuse Block 1987, where is it??
Old 10-28-2006, 12:31 PM
rhelwood
rhelwood's Avatar
Default Help, Auxiliary Fuse Block 1987, where is it??
I need a little help. I cannot find my Auxiliary Fuse Block which is listed as behind the center of the IP. I do not see it. Any help would be appreciated. I am changing the hazard relay......
Old 10-28-2006, 01:01 PM
RRT vette
RRT vette's Avatar
Behind the DIC (drivers information cluster) there is a fuse block. You have to remove the radio/climate control bezel. 4 or so screws hold it on. Once that is removed you need to remove the DIC and you should be able to see what you need. Cake job.
Old 10-28-2006, 01:06 PM
rick lambert
rick lambert's Avatar
I've never found an aux. fuse box on my 87, but the hazard flasher is located behind the drivers info. center...where the SES light comes on. Good luck. If there's a fuse box back there I'd like to know what fuses are in there? relays yes, flasher yes, fuses...I don't think so.
Old 10-28-2006, 01:10 PM
bogus
bogus's Avatar
that's where it is on my wifes 87... behind the DIC...
Now, as a thought, perhaps your has simply been pushed behind a panel or something.
Old 10-28-2006, 01:24 PM
RRT vette
RRT vette's Avatar
There are a few (3-4) fuses there. I know the CSV fuse it in there, I can't recall the others off hand.
Old 10-28-2006, 01:30 PM
rhelwood
rhelwood's Avatar
Thanks.
I can now see it. The Service Manual and Electrical Diagnosis SM Supplement call out the Auxiliary Fuse Block which is beside the Hazard Relay, Horn Relay, and a few other components.
So I just remove the Information Cluster which is held in place by four screws?
Old 10-28-2006, 01:33 PM
RRT vette
RRT vette's Avatar
Old 10-28-2006, 01:38 PM
rhelwood
rhelwood's Avatar
By the way, the Auxiliary Fuse Block contains the Theft Fuse (15A) according to the ESM.
It shows four slots. I will let you know once I pull mine out.
Old 10-28-2006, 05:13 PM
RRT vette
RRT vette's Avatar
Let us know when you get to it. I would like a reminder of what fuses are back there. I'm lazy.
Old 10-29-2006, 11:01 AM
rhelwood
rhelwood's Avatar
There are four fuse slots, but the Owners Manual, Service Manual, and my Vette use only three of the slots.
Hatch Auto (3)
Theft (15)
Blank
CINJ/CLU (5) (Listed as Crank in the Owners Manual)
To Help, Auxiliary Fuse Block 1987, where is it??
Quick Reply: Help, Auxiliary Fuse Block 1987, where is it??
