[UPDATE]: My Car is Fixed.... all high mileage L98s read within!!
Old 09-13-2001, 12:54 PM
scorp508
scorp508's Avatar
Default [UPDATE]: My Car is Fixed.... all high mileage L98s read within!!
Some of you may of known that my car was having an intermittent miss at high RPMs. Well Tuesday afternoon the car died completely and got no spark at all.
With the help of L98Terror, Phoenix, and Fastguy we got my car fixed and found the problem. My distributor gear as chewed up horribly, and finally 4 teeth broke clean off. I didn't get a shot of it yet, but I will as soon as I get it back (I left it in Fastguy's car). Every single tooth on the gear was worn down razor thing. If you saw this next to a new one you would crap your pants. There was almost nothing left of every tooth, and 4 of them were gone.
This allowed the distributor to skip completely out of whack (when it would turn) and blow my timing out of the water.
After installing a new gear from a distributor Fastguy had from his '75 (They are the identical distributor gear) the car runs like a champ again. My tachometer had been very very funky at high RPMs also. It would bounce around crazily anywhere over 4000. It would be at 4000, drop to 3500, back to 4300, just all over the place.... now it is smooth as silk all over the board.
So I think I would say to all high mileage L98 drivers, please check your distributor gear if you have a chance. It honestly isn't very hard to do at all. My car has 145.5k miles on her right now, and this thing self destructed. I am still going to have to pull the oil pan to fish out any parts that may still be sitting in there. :(
Old 09-13-2001, 01:23 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Default Re: [UPDATE]: My Car is Fixed.... all high mileage L98s read within!! (scorp508)
Remember the 'fix it' lists we put up a few days ago? Sounds like I just added another item to my list. 135k for me, so it sounds like a pretty good thing to check. Thanks for the heads up Scorp.
Old 09-13-2001, 01:33 PM
Kale
Kale's Avatar
Default Re: [UPDATE]: My Car is Fixed.... all high mileage L98s read within!! (90Ragtop)
hmnn. I can't find a "distributor gear" on any of the vette parts pages.
Old 09-13-2001, 01:40 PM
scorp508
scorp508's Avatar
Default Re: [UPDATE]: My Car is Fixed.... all high mileage L98s read within!! (Smash)
Probably won't either. Most places don't seem to carry them. I think ecklers (it's hard to find though) carries a Bronze replacement one which you have to run with certain types of camshafts. Ours are cast steel. (if i rememebr right)
This'll show ya' a few....
http://store.summitracing.com/defaul...rchType%3DBoth
[Modified by scorp508, 12:56 PM 9/13/2001]
Old 09-13-2001, 02:27 PM
LTxDave
LTxDave's Avatar
My IROC's distributor gear was pretty worn at 60k miles when I bought it. The rotor would turn back and forth about a quarter inch. Make sure thats the right gear, its a lot easier to replace dist. gears than camshafts.
Old 09-13-2001, 02:30 PM
scorp508
scorp508's Avatar
Default Re: [UPDATE]: My Car is Fixed.... all high mileage L98s read within!! (Mr Dave)
It is, but thats ok since I have a new cam/heads/intake waiting to go on anyways. :D
Old 09-13-2001, 05:11 PM
Fastguy
Fastguy's Avatar
St. Jude Donor '03-'05
My distributor gear as chewed up horribly, and finally 4 teeth broke clean off. I didn't get a shot of it yet, but I will as soon as I get it back (I left it in Fastguy's car). :(
Ummmm, yeah, well see, I got in my car to go to work today and put my shirt sleeve on the greasy gear you left on the console. I got pissed and whipped it out the window. :eek: I know where it landed though, I'll find it when I get home.
Old 09-13-2001, 05:22 PM
Stevmill
Stevmill's Avatar
Damn, I better check mine. I am at 178K. :rolleyes: :smash: :crazy:
Old 09-13-2001, 05:38 PM
7xchampcar3
7xchampcar3's Avatar
Default Re: [UPDATE]: My Car is Fixed.... all high mileage L98s read within!! (Stevmill)
ACDelco part # 10469459. It should not be more than about $23. Double check the part # if you are ordering one. The gear on my 41000mile GTA was sharp so it may not just be high mileage cars.
[Modified by 7xchampcar3, 9:41 PM 9/13/2001]
Old 09-13-2001, 05:39 PM
Midnight
Midnight's Avatar
Default Re: [UPDATE]: My Car is Fixed.... all high mileage L98s read within!! (7xchampcar3)
Glad you got it back running again. :D
Old 09-13-2001, 05:54 PM
scorp508
scorp508's Avatar
Default Re: [UPDATE]: My Car is Fixed.... all high mileage L98s read within!! (Fastguy)
Doh!! Sorry about that. I thought I had dropped it down in where the seat switches are?? :confused:
Old 09-13-2001, 07:38 PM
J Z06
J Z06's Avatar
thank you scorp..
i believe my original distributor is in my engine with 97k on the odometer. maybe this weekend we'll pull it and double check all the teeth on the gears. i can only hope lpe checked things over before putting it back in. remembering back, i know they put a different gear on it to make compatible with the 219 cam.
thanks again.......
Old 09-13-2001, 07:42 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
If you'd have done that, he probably would have waited till he was next to your car before he whipped it out the window.
Old 09-13-2001, 08:02 PM
phrogs
phrogs's Avatar
Im sorry but that is comedy you should have scorp do your laundry for a while :lol: good to hear you got it running :yesnod:
Old 09-13-2001, 09:11 PM
AquaMetallic94LT1
AquaMetallic94LT1's Avatar
Scorp, I would recommend that you pull the distributor and check the gear to see how it is.
I cannot remember for sure but I think stock roller cams require different distr gears than flat tappet cams. You need to go to a GM dealer and get the right gear for the cam. I don;t think the '75 gear is the correct one.
Actually, it might be a good idea just to get a new distributor.
Old 09-13-2001, 09:29 PM
AquaMetallic94LT1
Default Re: [UPDATE]: My Car is Fixed.... all high mileage L98s read within!! (AquaMetallic94LT1)
I looked at my Gm catalog. I think you need a special melonized (Don't knwo what melons have to do with it but.... )gear for the steel camshaft used in roller cam engines. You can also get a whole new distributor assy.
Old 09-14-2001, 12:01 AM
7xchampcar3
That part number I listed is the correct OE roller cam distributor gear.
Old 09-14-2001, 02:46 AM
Eric94
Eric94's Avatar
Glad you're back on the road scorp! :seeya
To [UPDATE]: My Car is Fixed.... all high mileage L98s read within!!
Quick Reply: [UPDATE]: My Car is Fixed.... all high mileage L98s read within!!
