Velcro fastener for convertible flap coming loose
Hi folks! This is a non-urgent issue, but is driving me a wee bit nuts... the velcro strip that holds the interior flap secure for the convertible roof on the passengers side is about to let go. I'd like to refasten it, but am worried that using too strong a glue or epoxy might make it impossible to remove/repair later? The normal glue that comes with velcro will be no where near strong enough to hold onto that flap as there is some pressure there.
So, I am wondering/hoping someone here would know the best method to reattach this to the roof frame?
Originally Posted by cajun86
I used apoxy and have had no problems.....
Originally Posted by wolverine1967
epoxy is pretty perm. i have the same issue and was going to go out and get velcro with the industrial strength glue back.
Originally Posted by TopSpeedC4
I wasn't aware there was such a thing! Is it readily available somewhere? Typical hardware store, sort of thing?
i found this place on the net
my vendor only has the squares not roll
http://www.instaoffice.com/Industria...FFPTECVEK90198
maybe it comes in black
keep looking
search for heavy duty velcro
keep looking
Awesome, thank you my friend! Yes, please, if you find others please do post the link. Now that I know what to look for, there is an arts and crafts store here closeby... that's totally awesome, thank you!
Stronger Glue
I have had the same issue with mine for about three years - and have not resolved it yet. Agreed, the glue that comes with the Velcro is too weak - it lasts for only a few days.
I HAVE managed to get the steel frame side of the Velcro to stick with a form of gorilla glue, but have not been so lucky with the Velcro on the 'vert top. The gorilla glue worked on the top for a couple of months but finally failed. Ditto the two-part epoxy I used. If anybody can recommend the name of a glue for the canvas top Velcro strip I'd appreciate the same assistance.
Good luck with yours, TopSpeed.
I'll definately post results next week when I get a chance to try this all out... I hope you find a way to fix yours, too, swifty... best of luck, my friend.
keep looking
HERE IT IS IN BLACK SAME LINK
keep looking
by Velcro USA, Inc.
List Price: $42.01
Our Price: $24.71
You Save: $17.30
Product ID: VEK90197
Sold As: 1 RL
Availability: 150+ in Stock
Quantity:
1 Post
Cruise-In XI, XII Veteran
NCM Lifetime Member & Ambassador
I went to a local auto interior shop that does tops. They did my '87 and '93 for $10.00. They cleaned off the old glue and replaced the velcro.
Originally Posted by sailrmon
They have the industrial velcro at Canadian Tire on Admirals Rd.I've got plenty of it.If you want some PM me and we'll hook up.Paul
Spare velcro strips are absoloutely indespensible when working on the interiors of these cars. Buy some for this project, and keep some extra around for a rainy day; you would be surprised at the applications. I've used it to remove almost all the rattles in the car and as an improvised "latch" for my glovebox. The adhesive is not permanent like epoxy but if you're patient and give it time to set, it should not peel off of the object even while the velcro is pulled apart; if all else fails, take a razor to the velcro hooks and weaken the velcro effect until the desired strength is reached.
Just to keep this thread up-to-date, in case anyone else is having this minor problem. New friends of ours popped by for a visit yesterday afternoon, with some heavy duty velcro in hand. We had an awesome visit, and it's becoming evident that Corvette people are a special breed, that's for sure.
Anyways, I used some real heavy duty solvent to clean up the mess left behind from the old velcro. We feel that it's likely the previous owner had done something to try and fix this before, as the glue/adhesive that was on there was rather unusual. Anyways, got most of it off. Applied new heavy duty velcro to window frame. Looks great, sticks perfectly.
Here's the kicker. The velcro on the flap (the original piece) will not hookup to the new heavy duty velcro we replaced. So, I guess I need to go to an upholstery shop or something and have the other half of the equation replaced as well.
Originally Posted by Aquaman92
Reglue it with Gorilla glue
Thanks for posting, my friend!!
