Rear Hatch Drain Tube Question???
Instead of placing drain tubes in the rear hatch area, could you just drill a small hole for the water to drain into? If so where does the water go? :confused:
Cruise-In II Veteran
Re: Rear Hatch Drain Tube Question??? (russell1755)
I would NOT drill a hole period. But hey, it's your car. I would think with no tube the dirt and crap would build up somewhere between the panel and the frame/chasis. :cheers:
Re: Rear Hatch Drain Tube Question??? (ConeKLR)
It goes into the car!
The little tube in the kit is for a second hole that takes the water into the wheel well.
