New Valve Covers Fit Without Modding
Tried one of my new covers on and it fits without modding. My huge energizer rollers required the stock cover's bolt towers to be shaved and the drip tabs removed. Finally something that hasen't pissed me off.
The ball milled lines will be powder coated yellow, as if you couldn't figure that one out.
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Gosh damn that's gonna look good! That sucker's really coming along. I think I'm almost as excited as you are!
St. Jude Donor '05-'06,'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
That thing is looking good....you going to fill the lines in with that powder kit you have? Glad to see you moving along
Pretty, I have a very similar set on my 89.
If those are the tall covers (as they appear) you should know that you EGR pipe won't reach over, and depending on the year, the aluminum trundle that holds the engine accessories will have to modified (read trimmed) by the rear A/C compressor mounting boss. In fact on mine I had to add spacers to move the compressor outboard by about 1/4 inch, to clear the covers. But it was worth it.
Good luck.
Good luck.
Good luck.
Good luck.
E.G.R., whats that Sounds like some of the alphabets i threw in the garbage, along with these alphabets. "A.I.R, C.A.T.S."
Only because I saw you had taped over the EGR port on the intake I figured you were still going to use it. I guess you powder coated the block-off plate seperately.
Cheers !
Cheers !
Originally Posted by Corvette Chris
Those valve covers are going to look sweet with the yellow.
How much longer until you are finally crusin'?
Cruise-In V Veteran
St. Jude Donor '06
Originally Posted by AGENT 86
I hope to fire it up next weekend, but i have been saying that for weeks.
...still hoping to actually see this car some day...
Originally Posted by msessine
What brand are the valve covers? I had to cut mine to clear the wiper motor, and yes what EGR?
Originally Posted by j3studio
Go for it...
Anyone selling time, i really need to buy some.
