CTSY/CLK Fuse keeps blowing
Old 04-19-2006, 05:50 PM
Leon10003
Leon10003's Avatar
Default CTSY/CLK Fuse keeps blowing
Hello all:
I have just incountered a new problem in which I require your help with.
The CTSY/CLK (15 Amp Fuse) keeps blowing on an 85 Corvette.
I have replaced it 4 times and it keeps blowing.
I can't seem to locate the cause?
Has anyone else had the same problem?
Can anyone suggest a fix?
Thanks,
Leon
Old 04-19-2006, 07:13 PM
mk842766
mk842766's Avatar
Default Been there, done that...
On mine, it was the pink/white wire that ran over to the driver's side door. Finally found the culprit by tearing out the dash, and tracing the wire....turned out to be a spot where the wire insulation was rubbed off, causing a short.....it turned out to be right behind the info center, just above the radio, but you couldn't see the wires until you took the entire dash out....Good Luck!!!!
Old 04-19-2006, 07:22 PM
Leon10003
Leon10003's Avatar
Thanks Man!
So it was a short........
I will see if I can locate my problem.
Old 04-19-2006, 07:34 PM
kittmaster
kittmaster's Avatar
Originally Posted by Leon10003
Hello all:
Thanks,
Leon
Make sure there is no loose change falling into the cigarette lighter shaft
Old 04-19-2006, 09:50 PM
jfb
jfb's Avatar
Check the hot wire going to the cigarette lighter that it isn't pinched or insulation abraded and touching ground.
Old 04-20-2006, 12:27 AM
bogus
bogus's Avatar
I had a case where the screw that retains the door light had come loose and was grounding out against the bulb.
Old 04-20-2006, 01:37 AM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
This is the circuit that most people tap into for aftermarket stereos and alarms. That'd be my first place to check.
Replacing the fuse will not fix it. And don't under any circumstances put a bigger fuse in.
Does it blow instantly? If it doesn't it'll be easier to diagnose.. unhook the battery ground and put a ampmeter between the cable and the battery post. Then start unplugging **** in the car until the amps drop down.
Old 04-20-2006, 06:24 PM
Leon10003
Leon10003's Avatar
When I attempt to replace the 15 amp fuse, it sparks out and blows.
If I disconnect the negative battery cable, insert the new fuse and re-connect the negative battery cable it is ok for a little while.
One time I closed the hood and the fuse blew.
Another time i drove down the street and the fuse blew.
Old 04-20-2006, 11:06 PM
Leon10003
Leon10003's Avatar
Still having no luck with this situation.
Old 04-21-2006, 12:34 AM
CentralCoaster
Do you have an aftermarket stereo or alarm? If so, disconnect them.
Electrical shorts take lots of patience and diligence.
Old 04-21-2006, 01:47 AM
Demonic85
Demonic85's Avatar
This fuse kept blowing with my aftermarket stereo so I put the original back in. No more blown fuses.
Old 04-21-2006, 08:28 AM
AGENT 86
AGENT 86's Avatar
This may help trace the problem. It's from my 86 but should be similar to the 85. http://members.shaw.ca/agent86/Clk-Ctsy%20Fuse.pdf
Old 04-21-2006, 08:34 AM
morgan_kane
morgan_kane's Avatar
Hood lights are also behind this fuse. So, maybe one of the hood light cables are broken, and closing hood makes short circuit. Check two wires coming from both of the lights to front of car, there are connectors near headlights.
Old 04-21-2006, 02:34 PM
thebeerman
thebeerman's Avatar
I bet you will find that someone tied in a hot wire to that fuse panel (look for a strand of wire stripped on the end that is shoved into the fuse box front or back), or that some one tapped the cigarette lighter hot lead for power to the stereo and it is shorting out (is it an aftermarket stereo? If so, pull it out and check the power inputs for bad connections, and wiring for fraying).
Old 08-22-2016, 06:56 PM
mzamora21
1st Gear
mzamora21's Avatar
Default Same Fuse CTSY/CLK blow out every time I open the switch
I have a similar issue so I disconnected the radio the boxes that control the AC and Heat also I check the lighter everything work fine until I open the switch and I can hear the fuse to blown also I disconnected the courtesy light I do not know what else can I disconnected
Any suggestion will thankful.
Old 08-23-2016, 03:37 AM
Cliff Harris
Cliff Harris's Avatar
The CTSY/CLK fuse supplies power to basically everything that works when the ignition is off. That would be all the interior lights, underwood lights and the antenna. The problem is that the circuit goes to so many places that it is hard to isolate them except by unplugging things one by one.
Old 08-23-2016, 06:57 AM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
Mention maybe the year of your car for starters. You mention "opening switch" - explain!
You might consider maybe starting a NEW THREAD or just search the C4 Community from here for CTSY/CLK
https://www.corvetteforum.com/forums...-1984-1996-19/
Use the SEARCH THIS FORUM "button" above THREADS/POSTS - that will keep your search in the C4 Community. There's 9+ pages and I'd think you'll find the year and a solution maybe. Year will matter.
To CTSY/CLK Fuse keeps blowing
Old 08-23-2016, 05:52 PM
Hot Rod Roy
Hot Rod Roy's Avatar
Here's a trick I've used when searching for a short circuit. It'll save you a bucket full of fuses!
Solder two wires to an old (but good) headlight bulb. Solder these two wires to the two little tabs on the top of a blown out fuse. Plug this fuse into the offending circuit. Most things will work just fine with this thing plugged in, but when you get a short, the headlight will shine, but nothing will smoke or spark!
Old 08-24-2016, 06:45 AM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
A coin in the lighter socket is the most likely cause of a blown ctsy fuse ....
Old 08-23-2022, 07:17 PM
ijakie1
ijakie1's Avatar
Originally Posted by agent 86
this may help trace the problem. It's from my 86 but should be similar to the 85. http://members.shaw.ca/agent86/clk-ctsy%20fuse.pdf
error:members webspace has been retired. Now what!!!
Quick Reply: CTSY/CLK Fuse keeps blowing
