40 psi In Tires
1 Post
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
40 psi In Tires
I know this just came up in another thread but I didn't want to cut in on the other posters action. My thinking was was that higher pressure would give you firmer sidewalls hence better handling on the corners. Such as tires not folding under on high speed turns. I'm running on Firestone Firehawk wide ovals and I realize I'm at the upper end of the spectrum on tire pressue. Should I lower it to 35 when I'm running an auto-X as well as on the street? Or even 32 psi? Always looking to learn. Thanks for the advice.
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
Go to Autocross Racing section of CF and ask same question. Should be interesting answers.
You'd think that was the case, but at that pressure, you're ballooning the tread and not even riding on the full contact patch. So while you may in fact gain side wall stiffness (I don't know), you lose traction/handling.
Location: Charlotte NC, behind someone going 10 under the speed limit
1 Post
St. Jude Donor '05-'06
As I said in the previous thread I work for GM mounting tires and the specs for passenger cars are 35psi + or - 3psi.40psi is not excessive but will affect tire wear.Higher than that is asking for trouble.Better to try 38 psi if you must.
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
I saw the post where he was running at 44psi (max allowed per the sidewall) and I wondered the same thing. I usually run ~ 35psi because running at the max scares me but, I don't really have anything to base that on, so I'm willing to hear what the experts say
Gary
Gary
1 Post
I've got (4) P275/40R17 98W on stock 90 Corvette wheels. From what I've read so far I'm planning on dropping to 32 psi pronto. Unless I hear something different. Went and cross referenced Auto-X forum as suggested by LT4Compyell. Lots of good info on beginners sticky.Also explained a little about the tire pressure. Beginners t.p. + 6 lbs. That's where I got the 40psi from. Adjust with experience.
Originally Posted by CMYC4GO
I run 40PSI in my tires, and I have had no significant wear problems. The car handles very well at high speed,on curvy roads.
Gary
Gary
Mine didn't
I went to an autocross driving school conducted by the local NCCC driving king (not sure of his actual title). He recommends 40 psi for agility during autocross.
35 psi should be significant. Over filling them causes premature treadwear and lose of traction. Bigger tires with more air pressure would seem to be a obvious soloution to traction but yet only a patch of each tire is on the ground as large as our palms(average size). So id advise to keep your tread up tire pressure at 35 and get good suspension to have better handling. Also a camberbrace/crossbar and other accessories have quite dramatic effects on the cars frame. Our C4s are flimsy in the bodys so it always helps to tighten it up and our stock shox are horriable compared to the gas ones used today. If im wrong someone please correct me
OK I'm no expert but I was always of the understanding that the MAX psi on the sidewall was just that max psi not to be exceeded. Like when tring to set the bead. I just always went by the placard. I think
tire psi. is some what subjective to conditions and prefercene. say +-3
But wouldn't that be just for the quick turn in and not alot of sustained high speed corners? He said 40psi for autocross only right? Not all the time I hope.
40 psi for autocross. For normal driving, I inflate my tires to 32 to 35 psi.
If you are going to the drag strip, deflate the rears for better traction and inflate the fronts for less rolling resistance on take off.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yup,
Miata tires and vette tires are like apples and oranges. Would this be different for wider tires? I see the contact patch being more sensitive to pressure on wider tires.
