AC Vacuum leak
AC Vacuum leak
My A/c has started blowing out of my defrost vents no matter what settings I have my controls set to. I have been told that it is probably a vacuum leak. Does anyone know where to start looking to find the leak.
Originally Posted by Redeasysport
3 way valve on the pass manifold.They sell them everywhere in the "Help" section.
Originally Posted by 95Torch
Hot dang...you're a genius! Thanks for the info. I pulled the pass side fuel rail cover off to expose the valve, only to find out that one of the hoses leading to it had become disconnected. I plugged it back in and now it works like a charm. I can't go without A/C here in Tx. Typical day January, one day it could be 30 degrees, the next could be 80.
